Suspension torq specs
Old Jul 31, 2007 | 12:16 AM
shikoz's Avatar
shikoz
Default Suspension torq specs
(I seemed to have misplaced my assebly manual) On the lower control arms and upper control arms, how tight should these be? I figured the uppers should be well tightened but I don't know the specs. The lower bushing seems to get cinched up if I tighten it too much giving it zero up or down movement. Lastly, how much should ball joint be tightend? I've got all new stuff and I don't want to screw this up!
Old Jul 31, 2007 | 01:28 AM
gothand's Avatar
gothand
Default RE: Suspension torq specs
You don't state the year if it matters and my scanner at home died, but here is what my FSM states
[ul][*]Lower arm ball joint assy to spindle slotted nut: 60-90[*]Upper arm ball joint assy to spindle slotted nut 60-90[*]bumper assy - suspension compression to body bracket stud nut 12-17[*]arm and inner shaft assy - upper suspension to body bolt 55-75[*]lower arm assy to underbody lock nut 35-50[*]lower arm strut to underbody lock nut 40-55[*]shock absorber assy to spring seat 12-17[*]shock absorber to upper mounting bracket stud nut 10-15[*]brake assy to front spindle lock nut 25-35[*]front stabilizer to lower arm stud nut 5-11[*]front strut to lower arm bolt 55-70[*]shock absorber upper bracket to body nut 17-25[*]front stabilizer to body lock nut 17-25[*]wheel bearing adjusting nut 15-20[*]shaft-upper arm spring seat to upper arm lock nut 17-25[*]wheel nut torque limits 6cyl 55-85, 8 cyl 75-110[*]upper ball joint to suspension arm 12-15[/ul]
Hope that helps.
Old Jul 31, 2007 | 09:44 AM
shikoz's Avatar
shikoz
1966 and thanks for that info! I didn't know you could put 60-90 lbs to ball joints. Interesting.
Thanks!
Old Jul 31, 2007 | 10:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: shikoz
Thanks!
According to my Haynes manual, it is definitely 60-90 ft. lbs ball joint to spindle.
Old Jul 31, 2007 | 11:22 AM
Norm Peterson's Avatar
Norm Peterson
Usually a ball joint torque spec also includes a note to tighten further if necessary to get the cotter pin hole to line up with the slots in the castle nut. Never, ever loosen the nut to assemble.
Norm.
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
