Knock Knock
Old Aug 2, 2007 | 10:34 PM
boss_dude_429's Avatar
boss_dude_429
Default RE: Knock Knock
[] oooooooooooo nobody SPEAK of lifters, okay picture this fresh 4.0 v6 i JUST put a new head gasket on, you have no idea what kind of a pain in the *** this is to get apart, now i got it all back together, first freash start, she cranks and what do i here.......tick.tick.tick.tick,*slames head on dash multiple times giveing himself a massive headach* how in the HELL could i forget the lifters, damit damit damit damit damit
Old Aug 3, 2007 | 08:05 AM
mikethebike's Avatar
mikethebike
Shade tree mechanic 101:
1. Knocks at 1/2 engine speed=lifter
2. Knocks on acceleration=broken piston
3. Knocks on deceleration=wrist-pin
4. Knocks all the time=big-end rod bearing
Old Aug 3, 2007 | 04:57 PM
mat11089's Avatar
mat11089
i dropped the oil pan and what do i find but a lot of metal shavings..i used the screwdriver method and couldnt really feel a deiff anywhere but i could hear it coming out of the front.I pulled each main cap one at a time and replaced in the same position and theyall appeared fine.i have oil pressure...The metal shavings look like pieces of aluminum but its abone stock late model 302 so i dont kno what could be aluminum..The knock had no rhyme or reason..Start and hear it then go away for awhile then back.When i started this morning is was loud at first then there but not as loud..im confused
Old Aug 3, 2007 | 05:54 PM
EmperorOfChicken's Avatar
EmperorOfChicken
who's there?
Old Aug 3, 2007 | 06:20 PM
Bulldog66's Avatar
Bulldog66
ORIGINAL: mat11089
Did you fire it back up after inspecting the bearings? I'm curious to hear what it sounded like. Metal in the pan is never a good thing. There'll always be some ( very little if at all ) present just from the age and wear.
Again, going to guess a rod bearing. If a main was spun, you'd have pressure issues and it'd be alot more obvious.
Old Aug 3, 2007 | 07:16 PM
mat11089's Avatar
mat11089
i believe i found the problem..
1. I thought maybe the eccentric cam for fuel pump was rubbing so when i took off lower pulley found the bolts had loosened and i shook it and it made the same sound so Check
2. The shavings were from the eccentric rubbing ill post a pic later its ground off aluminum from the timing chain cover..
So thanks everyone ill let u kno how it does once i change to an electric fuel pump and new gaskets and whatnot and fire her up.
Old Aug 3, 2007 | 07:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I knew it wasn't a rod bearing. Those suckers are very loud and clack all the time. Glad you found it. Get back once you get her repaired.
Old Aug 3, 2007 | 11:16 PM
boogerschnot's Avatar
boogerschnot
Good job,, at least you got to clean out the oil pan..
Old Aug 4, 2007 | 04:06 AM
mat11089's Avatar
mat11089
thats the way i looked at it.At first i felt stupid but then i thought well it got me to drop the pan and address the shavings before they got sucked through the pickup...Anyone got ideas for a electric fuel pump setup...So far looks like im order a painless relay P/n 50102 and mallory fuel pump P/N 4110 both from Summit...I am open to suggestions tho cuz u guys kno what ur talkin about.Ill have pics of the front cover tomorrow.You guys have got to see this.thanks again
Old Aug 4, 2007 | 09:02 AM
mikethebike
ORIGINAL: Soaring
When my brother-in-law called me years ago about a knock in his 280-Z my first question was...."does it sound like satan himself is inside your engine trying to beat it to death with a 24oz. ball-pean hammer?".....his reply was in the affirmative. When we took the engine down 3 rod bearings and the rear 2 main bearings were gone.
