9" ford rearend
Old Aug 2, 2007 | 07:10 PM
shr's Avatar
shr
Default 9" ford rearend
quick question.... on a 9" ford rear end (1972) if you dont have a step down in the outer axle tube size does that mean that you have a 31 spline rear, i know my 28 spline rear has a step down in tube size approx 6" in from the backing plates. thanks
Old Aug 2, 2007 | 09:57 PM
Daze's Avatar
Daze
Default RE: 9" ford rearend
65 & 66 Mustangs, Comets, Mavericks, and I believe Falcons had the step down tube. Prior to 1970 (I think) all 9" rear ends were 28 spline and from 70-72s both spline counts were used (there aging I am not exactly sure if the dates are correct or not but I am close give or take a year) so you are correct that all step down tubes were 28 spline, however Ford quit doing the step-down tube in 67 and there were lots of 9" rear ends (even the ones put in trucks) that had 28 spline until 72 so with you being on the change over year the only for sure way to know is to pull the axle and count the splines.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
mustangchef
Sep 4, 2015 08:08 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
67LimeCoupe
Sep 2, 2015 08:02 AM
