tci c4
Old Aug 4, 2007 | 10:20 PM
71mopar383's Avatar
71mopar383
Default tci c4
My new tci c4 doesnt go into reverse when it gets warm. Tci says the shifter is out of adj. I dont have the kickdown hooked up yet could this cause it?
Old Aug 5, 2007 | 02:27 AM
groho's Avatar
groho
Default RE: tci c4
the adj they are refering to should be a single bolt slide adj where the linkage bolts to the tranny shifter arm.it's a simple adjustment, and you only should need to move it 1/4in. forward or back to correct it, if TCI is right. i find neutral on the shifter inside the car, then find neutral on the tranny, and only then tighten up with bolt mating the two. The lack of a kickdown should only prevent the tranny from dropping to 2nd gear under load/acceleration.
poke68
Dec 16, 2025 03:36 PM
FD725
Aug 11, 2015 03:43 AM
moparmatt89
Aug 2, 2006 04:48 PM
OJMiles
Apr 29, 2006 09:40 PM
TOMB
Apr 18, 2006 11:09 PM
