engine block
Old Aug 6, 2007 | 08:09 PM
67mustang302's Avatar
67mustang302
Default RE: engine block
The only blocks from the factory that usuallycome with sleeves are aluminum
Old Aug 6, 2007 | 09:20 PM
LCC's Avatar
LCC
Just clean it up, I'm wondering about the connecting rod that came out of that hole. That's probably what made the damage..
Old Aug 6, 2007 | 09:50 PM
RSRXION's Avatar
RSRXION
I suspect that the cause of the damage is the result of a previous rod failure. I've seen my share of scattered engines and that type of damage is common. I agree that it will not affect performance and I also agree that you should touch it up with a grinder. Be careful not to get the grinder wheel against the bottom of the lifter holes. Good luck, Dean
Old Aug 6, 2007 | 10:12 PM
dcohen's Avatar
dcohen
the rod appeared to be okay, it probably was a rod though, in the 1st pic you can see a small spot in the opposite cylinder bore, it didnt really bother me
i guess the rod failed and they put a sleeve in it to fix the problem
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 05:21 PM
Sep 8, 2015 11:50 AM
