engine block
Old Aug 6, 2007 | 03:18 PM
dcohen's Avatar
dcohen
Default engine block
well i tore down my 289 today, everything looked pretty good EXCEPT the piston skirt on the # 1 cylinder has a "U" shaped chunk missing out of it, its about an inch wide
is the block ruined? i know theres no way to fix it, but is it one of those things that wont really hurt anything?
ill try to get pics up later
Old Aug 6, 2007 | 03:22 PM
jcomp's Avatar
jcomp
Default RE: engine block
Even if it did deeply score the cylinder, it can be sleeved and the block saved.
Some pics would be good.
Old Aug 6, 2007 | 03:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
Are you talking about the cylinder wall? If so, you can getyour cylinders sleeved. If it's the piston you are talking about just replace the piston. Take your engine to a machine shop and get it hot tanked then have a technician discuss your options with you.
Old Aug 6, 2007 | 03:25 PM
dcohen's Avatar
dcohen
its getting hot tanked sometime this week, its not the piston, or the sleeve, its the cast iron skirt
i was hoping to build a pretty mean 289 with this block, hope this doesnt ruin my dreams
Old Aug 6, 2007 | 03:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then that shouldn't be a problem. Just discuss it with the pro at the machine shop.
Old Aug 6, 2007 | 03:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
when they are talking about getting it sleeved I don't think you understand. what happens is the block is bored wider almost to the bottom of the bore and a new steel sleeve is pressed into the bore...it's like having a new perfect bore ...I had a block that had 2 rear cylinders cracked... if it's a special block you have may be worth saving. the bottom portion not bored locks the sleeve in place and the heads keep it from coming up out of the bore. works great in fact they sleeve cylinders alot in nascar after each race they often replace the cylinder sleeves
Old Aug 6, 2007 | 04:24 PM
dcohen's Avatar
dcohen
thats what im dealing with
Old Aug 6, 2007 | 05:39 PM
67mustang302's Avatar
67mustang302
That's not an issue at all, it's below the bottom of the piston skirt and well below the ring pack so it'll have no effect on performance. You may want to clean it up with a grinder a bit so it's all rounded and there's no jagged edges to create stress points and start cracks
Old Aug 6, 2007 | 06:01 PM
jcomp's Avatar
jcomp
Did you find the chunk of metal in there? If not then it might have been like that since the last rebuild.
Old Aug 6, 2007 | 08:01 PM
dcohen's Avatar
dcohen
i didnt find any chunks of metal, and im pretty sure that the engine has been rebuilt
did these engines come from the factory with sleeves?
other than that spot the engine seemed to be in great shape
