cowl ?
Old Aug 6, 2007 | 11:02 PM
eep4life's Avatar
eep4life
Default cowl ?
this my be a stupid question but what does the cowl do for my mustang what is its purpose... i was looking at mustangsunlimited catalog and saw cowl cover... and thought to myself if you can cover them... then why do you need them
Old Aug 6, 2007 | 11:04 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: cowl ?
The cowl is known for leaking, that's why you saw a cover for it.
It pulls air in coming across your hood and sends it throgh vents to cool your feet while driving.
Old Aug 6, 2007 | 11:13 PM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: cowl ?
When Ford put this assembly together,they forgot to paint it. It is very common for these to rust out. They go first, then the pans. There is about 170 spot welds to cut out if you fix this properly. Put some paint on it if you do the repair. The cover will work as a stopgap measure and buy time, but is not the true fix.Good thing is,it will keep your feet dry untill a proper repair can be made.
66GTKFB's Avatar
66GTKFB
Default RE: cowl ?
It also allows cool air into the heater so you get warm air to you and the defroster.
Jim
Old Aug 6, 2007 | 11:28 PM
dcohen's Avatar
dcohen
Default RE: cowl ?
when i did mine i put undercoating in there for extra protection, it actuall looks pretty good
Old Aug 7, 2007 | 12:25 AM
390bigblock's Avatar
390bigblock
Default RE: cowl ?
ha so wuts the best way to clean them out i have a leaves and stuff in my cowl
Old Aug 7, 2007 | 01:17 AM
andrewmp6's Avatar
andrewmp6
Default RE: cowl ?
390 id try taking the vent tube thing off under the drivers side have someone use a air hose in the vent blowing it to you using a shop vac. most aftermarket heat/air units dont use the cowl vent so you can weld it shut.
Old Aug 7, 2007 | 01:33 AM
390bigblock
Default RE: cowl ?
i dont have air or heat well not yet but ill try that way to clean it out
Nov 18, 2015 01:34 PM
StalkerGT
Sep 25, 2015 02:41 PM
Ipaman
Sep 22, 2015 07:01 AM
Sep 10, 2015 07:23 PM
