4 Link in a 65
Old Aug 8, 2007 | 03:43 AM
65PonyLove's Avatar
65PonyLove
Default 4 Link in a 65
Has anyone ever 4 linked thier pony?? I got a 65 with a horrible launch. I just burn out when ever I try to take off, which in turn is lost horsepower and slower times. I've been told that 4 linking it is the BEST way to go?? Am I right orare there other ways. I'm looking at about 1800-2000 for the kit then I would install it.
Old Aug 8, 2007 | 06:10 AM
andrewmp6's Avatar
andrewmp6
Default RE: 4 Link in a 65
my 68 use to have heidts bolt in 4 link kit if you spend a little more you can get it welded to a 9 inch housing. there bolt in kit is 900 the one welded to a 9 inch is 1700 prices aer from mustangdepot.com
Old Aug 8, 2007 | 07:01 AM
dodgestang's Avatar
dodgestang
Before plopping out money on a 4 link let me ask you a couple questions:
What leafs are you running now?
What shocks are you running now?
What suspension setup do you have in the front?
What tires are you using?
The reason I ask these questions is because with my stroker cleveland when I am at the track running on 17 drag radials, I have no problem launching at 2000 RPM and I have a simple 5 leaf and KYB in the rear setup with a road course style suspension setup (lower car, tight springs, nothing at all setup for drag racing). Granted I am waiting for a 3 link setup to work with my watts link, but I have different reasons for wanting it. On the track I have never had a traction issue. On the street I know that starting my car from a stop with full throttle I will never have any traction so I don't bother unless I want to try and put on a show.
Old Aug 8, 2007 | 08:26 AM
Soaring's Avatar
Soaring
I ♥ Acer
You have a Watts link Nick? No wonder you don't have a traction problem.
Old Aug 8, 2007 | 09:01 AM
andrewmp6's Avatar
andrewmp6
dodgestang you looked at http://www.evolutionmsport.com/evmCa...products_id=47 or http://www.lateral-dynamics.com/products/
Old Aug 8, 2007 | 09:11 AM
Soaring's Avatar
Soaring
I ♥ Acer
Here are some ideas. I think the IRS is intriguing. http://www.nzmustang.com/Newintoold/newintoold.htm
Old Aug 8, 2007 | 10:41 AM
dodgestang's Avatar
dodgestang
ORIGINAL: Soaring
My straight line traction has neither improved nor degraded since the addition of a watts link. A Watts link positively centers the rear to help overcome the side to side deflection of a solid axle in cornering.
Old Aug 8, 2007 | 10:42 AM
dodgestang's Avatar
dodgestang
I run the EVM watts link and I am waiting for them to complete the 3 link so I can install it.
Old Aug 8, 2007 | 01:24 PM
65PonyLove's Avatar
65PonyLove
ORIGINAL: dodgestang
Well as far as my leafs....they are stock and old, rear shocks something VERY CHEAP...I mean $30 for the pair. I just needed something in there so I could drive it to put miles on the new motor. The front suspension I'm not quite sure, but its all brand new...I had a shop re-do it when they ran my brake lines. And my tires are again cheap. only 40 each. So now that I've listed this it kinda brought it to my attention that maybe I have some other issues first. But the only reason why I went cheap on these is b/c it had been sitting for 5 years and I was very eager to drive it. I have a 8.8 out of an explorer in it right now with 3.73's and posi. So what could I do to launch?? If I dont have to get a 4 link then I wont but I dont wanna spend a few hundred less if thats the true way to go.....I'd rather do it right
Old Aug 8, 2007 | 01:31 PM
dodgestang's Avatar
dodgestang
IMO I think you will find that:
New 5 leaf and shackes: $180-200
New Rear Shocks: $35 each
Under rider traction bars: $100
Will greatly improve your car's starting ability. The term launching is something I reserve for the track, so perhaps a second set of cheap track tires for when you go racing are in order. The hard compound in the street tires at the $40 price point is a killer for starting with authority.
And to give you perspective on my
5 leaf mid eye springs
basic shackels
under rider traction bars
275 40 17 drag radials
Good enough for a 1.8 60 foot. Is it the best it could be...no. But it sure is fun and I wasn't suffering from wheel hop or tire slip.
Also, I don't think you have included the motor (how much power are you really pushing) and the rest of the driveline...auto/stick ratios, etc.
