Disc Brake Help
Old Aug 10, 2007 | 01:14 AM
Angelou's Avatar
Angelou
Default Disc Brake Help
Hello, I have a small issue. I purchased my 65 Mustang from my cousin, and found a broken wheel stud. My cousin did the disc brake conversion on the car. However he doesn't remember what car he got the disc brakes from. So I can't find a stud. Can I just replace the stud with one that "kinda" matches? Is there a handful of cars that the disc brakes could've came from?......My cousin thinks they came from an early 1970's Maverick. I checked it out...but Mavericks didn't come with disc brakes in early 70's. What are my options?
Old Aug 10, 2007 | 01:38 AM
degins's Avatar
degins
Default RE: Disc Brake Help
74-77 Maverick had disc brakes that are the same as Granada type.
Old Aug 10, 2007 | 02:01 AM
JohnnyK's Avatar
JohnnyK
Define 'kinda' matches.. Your main concerns would be thread pitch and diameter (Obviously) and the splines in the back to lock into the rotor. I would assume that if you could match those up, it wouldn't be much of a problem to cut it shorter and maybe clean up the ends if need be. Shouldn't have a problem finding a stud though?
Old Aug 10, 2007 | 08:54 PM
Angelou's Avatar
Angelou
Thanks...I just got the studs from a '76 Maverick, fit good. Thanks.
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
