automatic to stick
Old Aug 11, 2007 | 03:54 AM
xian67's Avatar
xian67
Default automatic to stick
i just learned how to drive stick in my friends integra and its so fun. way better than auto. what exactly do i need to switch from auto to stick?
Old Aug 11, 2007 | 08:57 AM
JamesW's Avatar
JamesW
Default RE: automatic to stick
Transmission & driveshaft yoke
Bell Housing
Flywheel
Clutch/Pressure plate
Throwout Bearing
Throwout arm
Roller bearing in crank
Different length draftshaft
Transmission Mount
Transmission crossmember
Clutch Pedal
Brake pedal
Clutch mechanism (cable, hydraulic, or standard equipment) dependent on the type of trans you're installing
Take off kickdown mechanism
Take off Vacuum line
Take off trans coolant lines
Old Aug 11, 2007 | 09:48 AM
66GTKFB's Avatar
66GTKFB
Shifter.
Some rewiring.
- and a bunch of bolts, brackets and nuts.
Jim
Old Aug 11, 2007 | 10:35 AM
superdavid's Avatar
superdavid
And money! Dont forget money! The other option is to just throw a rachet shifter onto your auto...
Old Aug 11, 2007 | 10:42 AM
JMD's Avatar
JMD
Will the OP need to buy a new hole for the floorboard or will the existing hole be ok???
I don't know for sureif the hole is the same for an auto and a manual, if it is different, someone here might be looking for an auto hole, you might be able to work out a trade or sell it or somthing...
Old Aug 11, 2007 | 11:05 AM
66GTKFB's Avatar
66GTKFB
Same mounting holes - but -
Add:
New speedometer cable.
New hole in firewall for speedometer cable (not sure - required on a 64-66).
Shifter plate.
Jim
Old Aug 11, 2007 | 11:12 AM
EmperorOfChicken's Avatar
EmperorOfChicken
ahhh I wanna do the swap too, but its so damn expensive!! im thinkin about just throwin a hurst quarter stick ratchet shifter into my car[]
Old Aug 11, 2007 | 12:32 PM
390bigblock's Avatar
390bigblock
im saving up right now to get a t-56 viper trans so much better than the t-5 or the tremek 6 speeds
Old Aug 11, 2007 | 12:34 PM
Smothers's Avatar
Smothers
ORIGINAL: 66GTKFB
Add:
Shifter plate.
Jim
I made the switch from C4 to Toploader and did not need: new speedo cable, new hole in firewall & there is no shifter plate (bolts right onto tranny).
Old Aug 11, 2007 | 12:46 PM
Smothers's Avatar
Smothers
ORIGINAL: JamesW
Bell Housing
Flywheel
Throwout Bearing
Throwout arm
Transmission Mount
Clutch Pedal
Brake pedal
What year car are we talking about? On my 65, I did not need some of the things listed here ie. used the same driveshaft without needing to alter it in any way.
