automatic to stick
Old Aug 11, 2007 | 01:28 PM
superdavid's Avatar
superdavid
Default RE: automatic to stick
He needs to pick out a tranny first... toploader or t5?
Old Aug 11, 2007 | 02:06 PM
66GTKFB's Avatar
66GTKFB
ORIGINAL: Smothers
ORIGINAL: 66GTKFB
Same mounting holes - but -
Add:
New speedometer cable.
New hole in firewall for speedometer cable (not sure - required on a 64-66).
Shifter plate.
Jim
I made the switch from C4 to Toploader and did not need: new speedo cable, new hole in firewall & there is no shifter plate (bolts right onto tranny).
The manual transmission speedometer cable is about four inches longer than the C4 type so you did a routing which leads to - 'kink city' (kinky is good - but not here). To accomodate the longer cable, the factory (remember them) punched a different hole in the firewall (Doh, what do they know) to accomodate the re-routing.
The shifter plate is the one that goes over the shifter boot (damn, forgot the top bootand the bottom dust boot - add those to the list).
Jim
Old Aug 11, 2007 | 02:27 PM
superdavid's Avatar
superdavid
My speedo cabel from c4 to t5 reached just fine, it just needs a new gear.
Old Aug 11, 2007 | 02:32 PM
Smothers's Avatar
Smothers
ORIGINAL: 66GTKFB
ORIGINAL: Smothers
ORIGINAL: 66GTKFB
Add:
Shifter plate.
Jim
Jim
I have driven about 10k miles since I made the conversion and there is no "kinking" problem. David Kee is the one who told me to re-use the same speedo cable (Doh, what does he know?).
I was confused on what u meant by shifter plate, I thought you meant shifter mounting plate.
He will also need a new speedometer gear for a accurate reading.
Old Aug 11, 2007 | 02:49 PM
66GTKFB's Avatar
66GTKFB
ORIGINAL: Smothers
ORIGINAL: 66GTKFB
ORIGINAL: Smothers
ORIGINAL: 66GTKFB
Add:
Shifter plate.
Jim
Jim
Love these quotes. I have no idea who David Kee is so if you use his input - so be it. To correct my last, the 67 body style uses the same access hole for all speedometers cables routed thru the firewall. In 64 to 66, Ford did it different for 4 speed MT's and 3 speed MT's and C4 transmissions. The 4 speed cable is longer because the speedometer output is on the right hand side of the transmission while the 3 speed and C4 outputs are on the left. So, in the real world, an automatic speedometer cable used on a 4 speed is gonna be 'stretched'.
Jim
Old Aug 11, 2007 | 04:35 PM
middiepride's Avatar
middiepride
ORIGINAL: 390bigblock
im saving up right now to get a t-56 viper trans so much better than the t-5 or the tremek 6 speeds
the t56 is the tremec 6 speed genius
Old Aug 11, 2007 | 05:25 PM
JamesW's Avatar
JamesW
ORIGINAL: Smothers
What year car are we talking about? On my 65, I did not need some of the things listed here ie. used the same driveshaft without needing to alter it in any way.
I was thinking T-5 when I noted the driveshaft change.
As for cost.... well, this modification can be range from $500 to $3000. The first time I did this, I found a guy parting out a '90 in good shape and got everything from flywheel back to the driveshaft for $500. Ended up doing the whole mod for about $1000. That was with a lot of fabrication and personal labor.
Old Aug 11, 2007 | 06:17 PM
390bigblock's Avatar
390bigblock
i ment it was beter than the tremek 5 speeds
Old Aug 15, 2007 | 06:04 PM
djsprinklesnjo's Avatar
djsprinklesnjo
ORIGINAL: EmperorOfChicken
ahhh I wanna do the swap too, but its so damn expensive!! im thinkin about just throwin a hurst quarter stick ratchet shifter into my car[]
ive seen these types of shifters, but how exactly do they work, whats the benifits and negatives, how much does the conversion costs. etc. any insight would be greatly appreciated.
Old Aug 15, 2007 | 08:31 PM
390bigblock
someone needs to make a triptonic trans ( paddle shifter )
b8checker
Oct 8, 2015 12:55 PM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
