need help finding a radiator filter
Old Aug 11, 2007 | 07:06 PM
az1966's Avatar
az1966
Default need help finding a radiator filter
does anyone know where I can find a good radiator filter? if so are some better then others? I gotta load of who knows what plugging up my cooling tubes? and need to find a way to keep it from happening again
thanks for help/info
Old Aug 11, 2007 | 07:37 PM
JamesW's Avatar
JamesW
Default RE: need help finding a radiator filter
http://www.midnightdsigns.com/Mustan...%20Filter.html
This unit works really well. I bought it about 6 years ago tho and the vendor I have listed doesn't sell them anymore. If you google it I think you can find it. I also know a guy that ordered 50 for a group buy on another board and may have one left. They run about 55 bucks
Old Aug 11, 2007 | 10:15 PM
az1966's Avatar
az1966
do you know if they have one left for a 66 200 ci 6 popper,,,prices sem to be all over the place
Old Aug 12, 2007 | 10:09 AM
noroof66's Avatar
noroof66
The Gano is tough to clean, but work well. Mustangs plus has them for $37.
Old Aug 12, 2007 | 11:45 AM
mikethebike's Avatar
mikethebike
I ran a Gano filter a few years back. Didn't like the results. The results being aireation of the coolant and a resultant increase in coolant temp from 180 to 205. When you put a light behind the filter the coolant looked like foam. I run a 3-row radiator with a S/S Flex-a-Lite 10,000 rpm fan, no a/c, 5-speed, power brakes. When I removed the filter the temps dropped back to 180 and as an experiment I allowed the car to sit at idle for 90 minutes without the temp increasing beyond 190.
Others on here have said the same thing about the temps and for some reason they don't mind driving around at 205 in a car with a 180 thermostat....I do.
I will say that if you have concerns about rust in your engines cooing system it may be alright to run one for a short period of time to trap the junk. I just wouldn't recomend it as a permanent item.
Old Aug 12, 2007 | 02:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here's the Tefba that JamesW has.
http://www.mako.com.au/auto/tefba.htm
Old Aug 14, 2007 | 11:21 AM
gestalt1's Avatar
gestalt1
There is a USA source for Tefba filters here http://www.fasterjags.com/Tefba.html
It is a Jaguar site but the filters will work just as well on Mustangs.
mtgldr
Feb 3, 2024 09:00 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
