Slightly OT Ford 360 question
Old Aug 13, 2007 | 03:11 PM
Watry's Avatar
Watry
Default Slightly OT Ford 360 question
I just bought a 1969 F100 with a 360 (FE) and C6 auto trans. The engine is quite tired. Two questions:
1. I have a line on a used 360 from a Bronco with a manual trans. I assume I can just change the flywheel to a flex plate? Are there balance issues on the pulley/harmonic balancer if you do that, or is it a straight bolt-on?
2. Where's a good place to go for standard rebuild pieces (pistons, bearings) if I end up rebuilding it? I'm looking to producea decent stock engine, nothing radical.
Thanks for any advice.
Andrew
Old Aug 13, 2007 | 03:16 PM
73 Sportroof's Avatar
73 Sportroof
Default RE: Slightly OT Ford 360 question
Are you sure the Bronco has a 360? I don't know of any Bronco that came with an FE engine.
Old Aug 13, 2007 | 03:21 PM
dcohen's Avatar
dcohen
i doubt that bronco has a 360 in it, what year is the bronco
78-79 broncos came with 400 and MAYBE the occasional 460
the rest of the broncos (80-96) used 302's and 351w's
a 360 is an industrial engine anyways
Watry's Avatar
Watry
I'm wrong; I was mixing my engine ads. See here: http://sfbay.craigslist.org/eby/pts/393114411.html It's a 1976 F150.
Andrew
Old Aug 13, 2007 | 03:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
That makes more sense. Broncos had the 302, 351W, 5.0 and the 5.8L engines depending on the year.
Old Aug 13, 2007 | 03:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Just google search for a rebuild kit. There are 5 zillion places to buy a complete overhaul kit.
Old Aug 13, 2007 | 03:44 PM
73 Sportroof
I think that the FE is internaly balanced. I put an automatic engine in a four speed truck and all I did was use my fly wheel.
Old Aug 13, 2007 | 05:05 PM
gothand's Avatar
gothand
ORIGINAL: Soaring
... and 170, 200, 289, 302, 351M, 400, 351W & 300.
Old Aug 13, 2007 | 05:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, Yeah, who gives a crap about those weak I6's?
Diode Dynamics
28
May 26, 2022 12:02 PM
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
ccwebb
Aug 11, 2015 06:47 PM
mustangfan305
Aug 7, 2015 11:09 AM
