oil
Old Aug 14, 2007 | 10:44 PM
mikethebike's Avatar
mikethebike
Default RE: oil
ORIGINAL: Soaring
ORIGINAL: mikethebike
ORIGINAL: Colorado_Mustang
You don't have a grasp of what these numbers mean.
The first number isn't the real viscosity, only the simulated viscosity at cold temperatures. How well the oil flows. The second number is the actual weight of the oil. A 10w-40 oil has the same viscosity as a 20w-40, but the 10w-40 has a larger usable temperature range.
ORIGINAL: 66GTKFB
If you use 10-xx weight in an older car you are asking for disaster. Minimum is 20 as in 20-40.
Jim
10w-40 for an older engine is fine. How much oil the engine uses will determine which time. If it consumes oil, then stick with the conventionals. If it's a fairly leak-free engine that doesn't use oil, go with full synthetic.
Well, you've got it wrong..the first number is the actual viscosity of the oilat something like 32 degrees and the second number is the high temp viscosity. They add enhancers to extend the range so it does not thin out.
All he need to do is run Castrol GTX 20/50 and he will be fine.
BS.. 20/50 is way too much. If you have to run that honey in that engine, it's time for an overhaul.
Let's see...1985 BMW 635 CSI...20/50 GTX, 1974 Spitfire 20/50 GTX, 1982 M-B 240-D...20/50 GTX, 1973 2600 Capri..20/50 GTX...1979 Fiesta...20/50 GTX, 1977 XLCH...20/50 GTX, 1992 560 SEC...20/50 GTX.....NONE needed overhauls. Not even after 350,000 miles. Oh, I forgot the 1990 twin-turbo 300-ZX...20/50 GTX, 1990 turbo AWD Talon...20/50 GTX, 2004 R1150-RT BMW mtorcycle...20/50 GTX. Shall I continue?
It's 20w at air temp and 50w at 250 degrees. Ever seen how thin 50w is at 250? I have. Pretty damn wattery.
Old Aug 14, 2007 | 10:59 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: oil
My synthetic 20w-50 is actually fairly 'thin.' But, still has the right viscosity to work very well in my '71.
MiketheBike...we're saying the same thing with different words.
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
