oil
Old Aug 13, 2007 | 09:09 PM
pflover's Avatar
pflover
Default oil
Im goin to change the oil on my 64 1/2 k code engine and i was wondering what you would use for the best protection and performance? What thicknessand brand would be the most useful?
Old Aug 13, 2007 | 09:33 PM
Daze's Avatar
Daze
Default RE: oil
How many miles are on the motor and what is the climate like where you live? For most applications a good 10-40 will work very well, but if you live in a place with cold winters go with 10-30. I like true synthetics, but that that is not a good choice for a motor with lots of miles on it.
Old Aug 13, 2007 | 09:46 PM
66GTKFB's Avatar
66GTKFB
Default RE: oil
If you use 10-xxweight in an older car you are asking for disaster. Minimum is 20 as in 20-40.
Jim
Old Aug 13, 2007 | 10:49 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: oil
Jim, I've never understood what those numbers mean
why would 10-xx be a disaster???
Old Aug 13, 2007 | 10:52 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: oil
You don't have a grasp of what these numbers mean.
The first number isn't the real viscosity, only the simulated viscosity at cold temperatures. How well the oil flows. The second number is the actual weight of the oil. A 10w-40 oil has the same viscosity as a 20w-40, but the 10w-40 has a larger usable temperature range.
ORIGINAL: 66GTKFB
Jim
10w-40 for an older engine is fine. How much oil the engine uses will determine which time. If it consumes oil, then stick with the conventionals. If it's a fairly leak-free engine that doesn't use oil, go with full synthetic.
Old Aug 13, 2007 | 10:59 PM
Aussie66Fastback
Default RE: oil
why synthetic if its an oil burner?
i would go cheap if its gunna burn it
what are the pros and cons of synthetic v mineral oil anyway?
Old Aug 14, 2007 | 04:26 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: oil
ORIGINAL: 66GTKFB
Jim
Hockey Puck Jim. I am running 10W40 in my 42 year old 289 and it is Royal Purple synthetic. The old addage that you can't run regular weight oil in old engines and especially the old addage that you can't run synthetic oil in old Mustang 289s is just BS and unfounded information.
Old Aug 14, 2007 | 05:14 AM
mikethebike's Avatar
mikethebike
Default RE: oil
ORIGINAL: Colorado_Mustang
ORIGINAL: 66GTKFB
If you use 10-xx weight in an older car you are asking for disaster. Minimum is 20 as in 20-40.
Jim
Well, you've got it wrong..the first number is the actual viscosity of the oilat something like 32 degrees and the second number is the high temp viscosity. They add enhancers to extend the range so it does not thin out.
All he need to do is run Castrol GTX 20/50 and he will be fine.
Old Aug 14, 2007 | 05:27 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: oil
ORIGINAL: mikethebike
ORIGINAL: 66GTKFB
Jim
BS.. 20/50 is way too much. If you have to run that honey in that engine, it's time for an overhaul.
Old Aug 14, 2007 | 08:00 AM
highhilleer's Avatar
highhilleer
Default RE: oil
If you really want to know about oil, go to:
http://www.bobistheoilguy.com/
Once you wade through the technical stuff, you'll find for classic engines a conventional 10W30 will be fine in most areas, a 10W40 would be good during the summer in the desert, and a 5W30 might be the way to go if you're driving the car in the winter in the north. If you feel the need to go synthetic, you're on your own. This only applies to older engines. More modern engines have more advanced engineering so check your owner'smanual and FOLLOW THE DIRECTIONS!
