What should I expect?????
Old Aug 14, 2007 | 11:00 PM
JPaikos's Avatar
JPaikos
Default What should I expect?????
I'm putting a fuel injected 5 liter along with a Tremec T5 in my '66 w/ the serpentine belt drive. What should I expect during the swap? Fitting?
Old Aug 14, 2007 | 11:24 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: What should I expect?????
http://www.midnightdsigns.com/james/
all you need to know
Also check out the FAQ section on the top
Old Aug 14, 2007 | 11:31 PM
restomod@16's Avatar
restomod@16
Expect to have headaches[:@]... I have not done the swap myself but from what I understand, the wiring is definitely the hardest part of the EFI. If possible try to get a buddy who is good with electrical wiring and schematics to come help, that would probably save you a number of hours. Other than that its not TOO difficult. James' website helped me a ton, even though I only did a few of the same things as him.
Old Aug 14, 2007 | 11:54 PM
JohnnyK's Avatar
JohnnyK
The wiring was pretty difficult.. Well, it wasn't that bad actually, but I haven't tried to fire it up, so maybe it was difficult.. I'm debating if it was necessary to run 4 relays (Ignition, fuel pump, eec, and O2 sensors).. Probably wouldn't hurt, but is it necessary, I dunno...
Fuel, on the other hand, is proving to be quite a dilemma.. not hard per say, but dilemmas.
Old Aug 15, 2007 | 06:19 AM
JamesW's Avatar
JamesW
Yeah...but once you're done....
You get a lot of these ...[sm=laughat.gif]
[IMG]local://upfiles/48409/683B1DFB3F7A4C74A1F2CDF5455A37D9.jpg[/IMG]
Old Aug 15, 2007 | 10:41 AM
JPaikos's Avatar
JPaikos
ORIGINAL: JamesW
Maybe.... But they wont be laughing when I blow by on the front straight. [sm=gears.gif]
CS2007
Jun 25, 2019 09:45 PM
Nov 18, 2015 01:34 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
