Plastic Radiator Overflow?
Old Aug 16, 2007 | 09:01 AM
  #31
dodgestang's Avatar
dodgestang
Default RE: Plastic Radiator Overflow?
ORIGINAL: mySAVIOReigns
haha, you can remove your foot from your mouth now...
I don't think anyone has their foot in their mouth on this one...this 100% opinion stuff so nobody is right or wrong.
Old Aug 16, 2007 | 09:12 AM
  #32
mySAVIOReigns's Avatar
mySAVIOReigns
no no, i know that.
It's because dstanger said Soaring's looked bad, and yours looked good; and yet, you have the same one.
  #33
scouttrooper's Avatar
scouttrooper
I bought a polished stainless one from summit. It mounted right up to the factory radiator bolts. It has inlets on the top and bottom. The hose runs out of the radiator to the bottom inlet like Soaring said, (stop picking on his tank ), and the top inlet has a hose that would direct any "overflow of the overflow" to the ground. If that spills a drop, then you simply have too much fluid in your system. If the system heats up, fluid expands and pushes out past my 13 lb cap into my resevoir through the bottom. As the system cools and fluid contracts, it develops vacuum and sucks on whatever is in that tube. I understand that it doesn't require pressure in the resevoir to push it back. However, I don't have any coils in my upper or lower radiator hoses, so when a vacuum forms, wouldn't it tend to collapse the hoses before it reached enough vacuum to drag fluid in past the 13 lb cap? Do I need to insert a volume maintaining coil in the coolant hoses?
[IMG]local://upfiles/58088/651F16247B9045D7B8BA3C40BC1EAB3A.jpg[/IMG]
Old Aug 16, 2007 | 09:24 AM
  #34
dodgestang's Avatar
dodgestang
ORIGINAL: scouttrooper
Not unless you have an overheating problem where when you drive at highway speed you persistently overheat and you can't figure out why. If you did have that problem you would add a spring to the lower hose.
Old Aug 16, 2007 | 12:42 PM
  #35
Rorin67's Avatar
Rorin67
Wow - I never realized that a $6 part, *** as it may or may not be, could warrant so much attention!
To add another question here - are the "fancy" cylinder tanks acceptable for the track? I know the track requires an overflow, but not sure how much fluid it must hold and if it's sufficient to pass tech inspection. Dodgestang?
Old Aug 16, 2007 | 01:42 PM
  #36
dodgestang's Avatar
dodgestang
ORIGINAL: Rorin67
You can pass tech at most track with a coke bottle and duct tape.
Yes they pass tech
Old Aug 16, 2007 | 02:12 PM
  #37
Boneyard's Avatar
Boneyard
I just bought one today at Kragen autoparts for $7. Here's the link...
http://www.partsamerica.com/ProductD...egoryCode=3052
Old Aug 16, 2007 | 05:03 PM
  #38
dstanger's Avatar
dstanger
no no, i know that.
Hey, I never said anyones (especially not soarings!) looked bad. I just have seen some of the metallic ones that don't look good on the fenderwell. Some of the ones I've seen on this post look great, especially the metal one that is right beside the radiator that someone posted a pic of. That looks good, might have to get that one!
Old Aug 16, 2007 | 05:21 PM
  #39
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: dstanger
no no, i know that.
You are right, it was Fastbackford351 who said my white plastic tank looked like ***. If you go back and read what Nick said about why he took off his metal tank that was attached to the radiator and got the white plastic tank that is mounted on the inner wheel well you will probably wind up just like Nick and me and have the tank that looks like *** because it is functional, not pretty.
Old Aug 16, 2007 | 05:39 PM
  #40
Soaring's Avatar
Soaring
I ♥ Acer
No, you will not have pressure in the overflow tank, if fact you need to have a pin hole in the top of the tank to allow air to get out. Only enough amount of the heated coolant goes to the radiator for cooling and this goes back to the engine to absorb heat once again. When the engine cools, vacuum is created in the cooling system since it is a closed system. This causes the coolant in the radiator overflow tank to be sucked back into the cooling system.
