c4 tailhousing
Old Aug 15, 2007 | 04:49 PM
Mustangdemon67's Avatar
Mustangdemon67
Default c4 tailhousing
how long is the stock auto c4 tail housing? im getting the overdrive addon from gearvendors but im not sure of the lenth
Old Aug 15, 2007 | 05:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: c4 tailhousing
I dug around and found this. Any help?
C4 and AOD Dimensions
Overall Length (bellhousing to tailshaft housing end, flat-to-flat):
AOD - 30 3/4"
C4 - 30 1/4"
Notes:
"Engine Swapping Tips and Techniques" lists C4 length as 27 3/4" (C6 length
28 1/2" or 28 3/4"). I may have measured to the end of the output shaft,
not to the end of the tailshaft housing.
Distance from Bellhousing to Insulator Mount (flat to mounting hole centerline):
AOD - 21 3/4"
C4 - 19 3/4"
Torque Converter Stud Spacing (centerline-to-centerline)
AOD/C4/164 teeth flexplate - 8 1/4" between closest studs, 11 7/16" between
farthest studs (stud pattern diameter)
C4/157 teeth flexplate - 7 3/4" between closest studs, 10 5/8" between
Transmission Lengths from "The E4OD", Ford High Performance, April 1995
Trans Bellhousing Overall Length
Face to Trans From Bellhousing
Mount Length To Tailshaft End
C4 20 1/4" 30 1/2"
C6 22 1/2" 33 1/2"
AOD 22 1/4" 30 3/4"
E4OD 29 3/8" 37 1/2"
Old Aug 15, 2007 | 05:17 PM
Mustangdemon67
yup, thanks soraing, this is the little chart i was using, i think i know which one it is, the one i put it green
FORD Application Guide 2-Wheel Drive 3-Speed Automatic
Part No.
Application
Description
Comments
Price
Code
3D0042
C5/C4 Short fixed yoke 3-Speed Automatic
Replaces 8" tail housing.
C4-C5 fixed yoke uses 4x4 adapter ZF nose custom.
D
3D0040
C-4 3-Speed Automatic
Replaces 13" tail housing.
Ford Light duty vans, pickups and cars.
B
3D0041
Shorty C-4 3-Speed Automatic
Replaces 13" tail housing. Converts long shaft C4 to short 4x4 version. (That's 5 1/2" shorter).
Muscle Car applications with limited tunnel & driveshaft length. Note: If already a 4x4 version, use price code C.
E
3D0060
C-6 3-Speed Automatic
Replaces 14" tail housing. Also see 3D0063 below.
Ford Vans, pickups, class C motorhomes, and cars including motorhomes, passenger cars and Diesels.
B
3D0063
Shorty C-6 3-Speed Automatic
Replaces 14" tail housing. Uses GV supplied output shaft.
Used for Cobra kit cars and other short wheel base cars. Shortens package by 10". Some early model trucks fixed yoke.
F
Click Here for Price Schedule
info@gearvendors.com
Old Aug 15, 2007 | 05:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK Demon, glad you are making some progress.
waldo786
Oct 20, 2007 07:10 PM
moparmatt89
Nov 27, 2006 12:34 PM
Jim Allen
May 28, 2006 11:14 PM
86HOGT
May 24, 2006 01:25 AM
jmmorgan82
Dec 12, 2005 02:38 AM
