Fuel Gauge
Old Aug 16, 2007 | 06:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Fuel Gauge
ORIGINAL: JMD
There is an outside chance that in the course of rewiring the sender, that the connection between the stud/screwand the wire may be less than ideal. If this is the case, then there may be just enough extra resistance to throw the gage off kilter. These gages use very small amounts of current, any disruption may cause false readings.
Mine has always read 3/4 when the tank is full. I replaced the entire wiring harness and sending unit a few months ago, and she still reads 3/4. I have no doubt that my problem is the gauge itself, and most likely everybody else's who get a false reading at the gauge. I may try ordering a new gauge just to prove my point.
mySAVIOReigns's Avatar
mySAVIOReigns
JMD - I tested that last night. It turned out it was reading incorrectly, slightly. I tightened it on the stud this time correctly (last time I did it at the gas station by hand). So that helped, a little. Thanks Soaring, I will give that a shot.
Old Aug 17, 2007 | 05:42 AM
Arcticspook's Avatar
Arcticspook
Mine reads 3/4 when I fill it up. When it reads 1/4, I head to the WaWa and fill it back up.
I am living with it for right now but it's on the list of things to fix after I get the transmission looked at.
Old Aug 17, 2007 | 10:53 AM
JMD's Avatar
JMD
ORIGINAL: Soaring
ORIGINAL: JMD
I don't doubt you a bit Glen. With your knowledge of these cars you don't need to prove anything to me...
My reading of the original post led me to believe that the gage may have worked properly prior to My Savior replacing the tank, The float, sender,andgauge issues had already been covered so I wanted to add the possibility that the connection might have been poor.... I didn't want to see the OP spend a bunch of money over a bad connection!!! I knew that this was an outside chance, but still a possibility...
Take care Glen!
Old Aug 17, 2007 | 12:53 PM
Nabster's Avatar
Nabster
I'm lucky to get a reading of more than half a tank when in reality the tank is more than full. Used to only be a quarter of a tank low on the reading but it's just gotten lower as of recently. Makes me think the main problem I have is a bad float. I know it wouldn't hurt to replace the tank though, the car did sit outside our house for years with gas in the tank, but it did immediately start up when we put a new battery in after all those years.
Makes me wonder if the people who built these mustangs also built gremlins
Old Aug 17, 2007 | 01:58 PM
Art Brock's Avatar
Art Brock
My problem turned out to be a bad conncection at the tankalso. I pulled the wire off to check the sending unit & it all checked out OK so I put the wire back on the stud. Checked the gauge & it was reading correctly now so I guess it was a loose/bad connection. I was happy.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
