Cable clutch conversion
Old Aug 17, 2007 | 04:18 PM
jravenea's Avatar
jravenea
Default Cable clutch conversion
All,
I've been reading a lot of stuffs about cable clutch conversion but still don't quite get it
- My car is a 68 coupe / 302.
- Was originally 4 speed, converted to a 5 speed (probably T5 ??)
- I understood that either the bellhousing could have been replaced or kept original. I don't know what was done
- I have the original linkage.
I have some work to do on the clutch linkage, it is worn, bushings were gone a while ago and the pedal won't return all the way up. Plus for some reason the pedal linkage going through the firewall scratches against the firewall instead of being in the center of the hole. But that's another story.
So I was considering the opportunity to upgrade to a cable clutch.
However, to my level of understanding a cable clutch is going to pull the clutch fork forward (towards the engine) while my current setup pushes the clutch fork backward (toward the rear of the car)
Does this mean I can't us the kits available out there to convert my car? Or is there something I'm missing ?
Thanks
JC
Old Aug 17, 2007 | 04:25 PM
Rorin67's Avatar
Rorin67
Default RE: Cable clutch conversion
If you have a 5 speed and the original clutch linkage that "pushes" the clutch fork, then your 5 speed is likely hooked up to the original 4spd bellhousing. A cable clutch system would work, but you would have to alter your bellhousing (i.e. take it off and weld in a fulrum adapter). If you really want a cable clutch, then it may be easier to just acquire a 5 spd bellhousing and get rid of that 4spd bellhousing. Your cable clutch system will bolt right up to that without any modification.
Old Aug 17, 2007 | 04:26 PM
Rorin67's Avatar
Rorin67
Did I mention that I HATE mechanical clutch linkages!!! [:@][:'(][:@][:'(]
Old Aug 17, 2007 | 04:27 PM
TexasAxMan's Avatar
TexasAxMan
I don't know about the cable conversion, but replacing the bushings should be pretty cheap and easy, and it will probably solve the other problems you mentioned.
If I'm wrong (probably) I'm sure someone will correct me.
Old Aug 17, 2007 | 04:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Rorin67
Why don't you tell us how you really feel?
Old Aug 17, 2007 | 04:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Did you read this one?
http://www.mustangsteve.com/cable.html
Old Aug 17, 2007 | 04:39 PM
jravenea's Avatar
jravenea
Thanks Rorin67, this helps.
As much as I don't like this mechanical linkage myself, sounds like quite a bit of work... I might just try to rebuild my linkage as advised by TexasAxMan..
In that case I have to solve this firewall / pedal linkage issue which is part of the problem. I'll post some pictures later today for your advices
Thanks
JC
Old Aug 17, 2007 | 04:41 PM
jravenea's Avatar
jravenea
Yeah, this is what I was looking into. But seems to be for T5 bellhousings only... Since I know now I have the older bellhousing with the 'push' type fork, this won't fit without fab or bellhousing change.
Old Aug 17, 2007 | 04:44 PM
JMD's Avatar
JMD
This is a good kit, but you will need to change the throwout arm as Rorin67 stated above.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
