Calling 393 strokerz
Old Aug 18, 2007 | 01:01 AM
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
Default Calling 393 strokerz
Just bought a complete 1969 351w and was planning to do a master rebuild, but I rememberd someone saying that I can make a 393 really cheap. I know a 393 stroker can be done by simply putting in 302 pistons and a different crank.
-What kind of crank do I need?
-What kind of machine work needs to be done?
Old Aug 18, 2007 | 09:42 AM
69mach1377's Avatar
69mach1377
Default RE: Calling 393 strokerz
Stoker kit is your best bet, many are available so check around.
Old Aug 18, 2007 | 10:18 AM
my77stang's Avatar
my77stang
fullauto (a member here) can get you stoker kits for really cheap. but your right on the 393, they are cheap to do its just that the stroke/rod length is a crappy combination
Old Aug 18, 2007 | 11:34 AM
JMD's Avatar
JMD
ORIGINAL: my77stang
+1,,, part of building an effective stroker is getting as long a rod as practical in the engine,,
I spent a long time doing engine math to select my own components and to select and buy them separately, in the end it was much cheaper to go with a kit, and lots easier as well. Remember balance!!!, get a kit and buy the kit balanced...
Old Aug 18, 2007 | 11:50 AM
my77stang's Avatar
my77stang
FYI even balanced kits need to be balanced. they are usually only balanced to within a factory accepted spec, which is not what we think of when we think "balanced"
Old Aug 18, 2007 | 02:40 PM
ShAkE N BaKe!!
Buying a stroker kit is way out of my budget. Im just wondering if a 393(just adding 302 pistons and a diffrent crank) would be "better" than a master rebuild?
Old Aug 18, 2007 | 07:29 PM
69mach1377's Avatar
69mach1377
No, not at all.
jerrytubes
Oct 23, 2015 12:11 PM
ChampInSD
Oct 2, 2015 04:55 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
Demodulates
Sep 18, 2015 11:14 AM
