fan shroud
A stock one would work as the shroud is dependant on the radiator, engine and fan type. As a 302 is the same size as a 289, no problem. A three or four rowradiator poses little problems although you might consider a 68 302 fan spacer for better clearance. That leaves the fan, stock or even a Ford five blade will fit, maybe even a clutch type. Anything else?
Jim
Jim
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
