valve lash again
Old Aug 19, 2007 | 11:34 AM
paddy187's Avatar
paddy187
Default valve lash again
Ok my valve train is making the ticking noisesand so I though ok valve lash again, so checked the lash like the method in how to rebuild small block fords by tom monroe and everthing is fine.But when starting samenoiseso either I have not tightened enough or could I have a deeper problem? I will re-check the valve lash as the way in FAQ later in the week. Any ideas what else it could be?
Paddy
Old Aug 19, 2007 | 02:57 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: valve lash again
Does the tick go away after it's warm? If so, no problem, just a little loose.
Old Aug 19, 2007 | 03:42 PM
paddy187's Avatar
paddy187
no it there when warm unfortunatley
Old Aug 19, 2007 | 04:32 PM
Colorado_Mustang
Do you have screw in studs or the stockers? The stockers will push out of the head with a larger than stock cam...
Old Aug 20, 2007 | 12:30 AM
paddy187's Avatar
paddy187
I believe the cam is stock as are the arms which are stud mounted.
Old Aug 20, 2007 | 03:57 AM
Soaring's Avatar
Soaring
I ♥ Acer
Most likely your rockers are worn, therefore they need to be tightened a tad more than factory specs.
Old Aug 20, 2007 | 05:34 AM
paddy187's Avatar
paddy187
I am thinking of taking old valve cover and cutting open topso I can adjust when running with out loosing to much oil. Somebody did the same so sound like a use for them
Old Aug 20, 2007 | 05:48 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that'll work if you can find some old valve covers to cut up.
Old Aug 20, 2007 | 06:24 AM
paddy187's Avatar
paddy187
being less OEM then you glen, I changed my horrible powered by ford covers for chrome and black chrome ford racing, now I need some one with an angle grinder.
Old Aug 20, 2007 | 10:59 PM
Colorado_Mustang
I have one of those special valve covers. I still lose oil, but not as bad.
BTW, the stock torque spec of 20lb-ft would still apply. You don't have adjustable rockers, so cutting a valve cover won't help you much.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
TfcCDR
Sep 14, 2015 12:08 PM
