alignment specs
Old Aug 19, 2007 | 10:28 PM
Jakaru's Avatar
Jakaru
Default alignment specs
I know I know I used the search feature and this is what I came up with.
STREET
Caster: +1.5° to +2.5°
Camber: 0 to -.5°
Toe: 1/8"
I just actually got my suspension and stearing done and was wondering what are the specs I should look for. stock 4 leaf rear and one inch down with 620 springs in front.
Old Aug 19, 2007 | 11:30 PM
Daze's Avatar
Daze
Default RE: alignment specs
I print out this information and take it to the alignment shop"
Please align to these specs “1960-1966 Mustang and Falcon Performance Alignment".
These specifications are in order of importance.
1. NO more than .25 degrees difference between driver’s side and passenger’s side.
2. +2.0 to +3.5 degrees caster.
NOTE: for cars with Adjustable strut rods. Please attain as much caster as possible using the shims (at least 1.5 to 2.0 degrees), and then use the adjustable strut rods to increase the caster and make the sides the same. Also, please note that the caster difference between the driver’s side and passenger’s side needs to have no more .25 degrees difference prior to the adjustment of the strut rods.
3. -.5 to 0 degrees camber. No positive camber, please. There is no problem having a slight variation from driver’s side to passenger’s side to account for the crown in the road.
4. 1/16" to 1/8” toe in
If you run into any problems attaining these specs, please call me (your phone number here).
Old Aug 20, 2007 | 12:03 AM
67mustang302's Avatar
67mustang302
Make sure your camber is 0 or negative, the factory style suspension and positive camber generally = outside tear wear(sometimes excessive depending on how you drive) and crappy handling.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
