problem with my intake manifold
Old Aug 20, 2007 | 05:47 PM
eep4life's Avatar
eep4life
Default problem with my intake manifold
ok so i bought a new intake manifold for my 302 but there seems to be a promblem.... the bolts that are comming up from the heads that you put a nut on there coming up to short and there is not enough space to put the nut on... when i do it starts to tighten but then it will strip the nut and i already tried torquing down all the bolts to see if it would give a little more space but no go... any ideas
Old Aug 20, 2007 | 05:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: problem with my intake manifold
Start from the beginning. Why did you decide to replace the intake in the first place? Which intake manifold did you buy? Which gasket did you use? Which engine do you have.?
Old Aug 20, 2007 | 06:05 PM
eep4life's Avatar
eep4life
ok so i bought a intake manifold because i needed one, from summit racing. it is just one of there brand intake manifolds, its description is... " Intake Manifold, Stage 2, Dual Plane, Aluminum, Natural, Square Bore, Ford, Small Block 260-302, Each" i used the gaskets that came in my gasket set for the whole motor. i have a 302 out of a 69 coupe
Old Aug 20, 2007 | 06:08 PM
66GTKFB's Avatar
66GTKFB
Remove the stud and use a long bolt.
Jim
Old Aug 20, 2007 | 06:11 PM
eep4life's Avatar
eep4life
ok so the studs just come out by turning them like a normal bolt....
thanks Jim
Old Aug 20, 2007 | 06:24 PM
JMD's Avatar
JMD
ORIGINAL: eep4life
thanks Jim
Yea they come out, you might need to put two nuts on the stud to get them out,,, but it should work...
Old Aug 20, 2007 | 06:30 PM
my77stang's Avatar
my77stang
vise grips FTMFW!!!!
Old Aug 20, 2007 | 06:36 PM
66GTKFB's Avatar
66GTKFB
ORIGINAL: my77stang
You represent the worst of the Mustang world with that statement - joke or not.
Jim
Old Aug 20, 2007 | 06:57 PM
my77stang's Avatar
my77stang
oh come on, they are one of the best tools a person can have in their box.
(really, they do come in handy)
Old Aug 20, 2007 | 07:04 PM
eep4life's Avatar
eep4life
well thanks guys... i got on there... im hoping to try and start her up on wed.... wish me luck
