a whole new problem
Old Aug 22, 2007 | 07:42 PM
eep4life's Avatar
eep4life
Default a whole new problem
i finally got my motor and trans back in my car and realized that i forgot to put that cap that goes on the back side of the motor where the cam is.... i guess ill have to pull it all out tomorrow....
Old Aug 22, 2007 | 09:54 PM
JamesW's Avatar
JamesW
Default RE: a whole new problem
What made you realize it was missing? the cap in your hand?
Old Aug 22, 2007 | 11:17 PM
eep4life's Avatar
eep4life
actually i was tearing in to my old block removing the crank and pistons ect... when i saw it on the old block.... then i remembered and i checked in the trunk were i keep all my parts and sure enough it was there still..... so now i have a whole new project to start tomorrow... i feel like im never going to get her done..... but slowly i know it will
Old Aug 22, 2007 | 11:20 PM
JMD's Avatar
JMD
That sucks!!! Would it be any easier for you to drop the trany and install the plug???
Old Aug 22, 2007 | 11:57 PM
67mustang302's Avatar
67mustang302
All 6 of your oil gallery plugs are in too, right? 3 screw in ones in the back, 3 press in the front. You miss 1 and have 0 oil pressure
Old Aug 22, 2007 | 11:59 PM
boogerschnot's Avatar
boogerschnot
wow, that sucks,, I was just wondering if you had gotten the electrical system back together!.. [:@]
Old Aug 23, 2007 | 12:26 AM
eep4life's Avatar
eep4life
crap now you guys got me worried.... were do those other plugs go... i know the ones on the sides of the block are in.... the gold ones the size of a half dollar... what do the otheres look like
Old Aug 23, 2007 | 12:28 AM
JMD's Avatar
JMD
Smaller,, like 1/4" pipe plugs.... they usually come in the same kit or "card" that the freeze plugs come in/on.
Old Aug 23, 2007 | 12:37 AM
67mustang302
Yeah, 1/4" plugs and they go at the end of the oil galleries around the #1 cam bearing bore, behind the timing gearunder the timing cover. If you left those out, even 1, you'll have no oil pressure. There should be 3 screw in plugs in the back of the block around the large press in plug you left out, like pipe plugs
Old Aug 23, 2007 | 12:39 AM
eep4life's Avatar
eep4life
where are they located on the block.... wiould they be behind the timing chain cover and in front of the bell housing.... if possible could some one find a photo...... now im worried... and i cant tell if there in there..... you see the block that im using i bought off of some one... they had work done to it.... when i got it... it had been bored over, the crank, pistons and cam already installed as well as the timing chain, the freeze plugs.... but i dont know about the otheres.... im guessing if they usually come with the same kit then the guy installed them already but i dont know.....
