overheating
i recently put a 347 stroker in my65 mustang.. it was over heatin to about 220 degreess and on and i had to pull over jus drivin about three blocks..i bought an electric fan and about to put a shroud. any thing else i may do or i could do? thanks i need some help
What radiator do you have? If it's a stock radiator and you have a healthy build, all the fans and shrouds in the world aren't gonna fix the fact that you have an inadequate radiator
Have your radiator rodded out if it is old and has not been rodded in the last few years. You may need to get a new radiator with more rows of tubes, like a 3 row, or a 4 row. A 4 row would be your best bet to make sure that you have enough radiator to get the job done.
A 2 row aluminum is an option as well, we bought this one a while back, it is American made and is well built IMO.... and a direct bolt in, except that you will find that the shroud brackets are a little short, we found a work around for this issue. If you decide to go this route I can fill you in on what we are doing....
http://store.summitracing.com/partde...p;autoview=sku
http://store.summitracing.com/egnsea...40&NeXID=5
With a 347, you should use a cross flow radiatator, stock design is inefficent. Northern makes the Summit rads, and several generic Ford designs. I'm using a 9609 model that is 26" wide, including side tanks, and has a trans cooler. Easily fits between my 65 front rails. AFCO is another high quality, yet economy Mfgr. You'd need a 70 model water pump, or a crossover tube, and be aware a pet **** port doesnt come on the rads, but can be added.
ORIGINAL: Mr. Classic EFI
Anyone else ever heard this on am I retrieving a non-existent memory?
I know I read that somewhere...Years ago I had a GM 27" crossflow radiator cut down to 18" and converted to top/bottom flow for my 39, it kept my 402 BB cool as a cucumber....
Years ago those aluminum units were big bucks..... bucks I didn't have.... now some of them are economiical...
Crossflow, as I understand it, Inlet and outlet are in opposite diagional corners. The staggered orificesprevent the coolant from taking the path of least resistence, as it would with both inlet & outlet on the same side. Orifice side coolant flows fast, no orifice side coolant hardly flows. Direction doesnt mater, Water dont like to go the long way.
??? Did I answer that or confuse it???
Will this do the same thing?
Here's a little info on AFCO aluminum rad install.
http://www.midnightdsigns.com/Mustan...r_install.html
