EFI Mods ?
Old Aug 24, 2007 | 11:49 AM
takeoutexodus's Avatar
takeoutexodus
Default RE: EFI Mods ?
Hmm , I will do further research on this topic .
Thanks for the info .
Anyone else got an answer?
Old Aug 24, 2007 | 11:57 AM
67Stang68's Avatar
67Stang68
You can use a billet spacer and remove the egr valve, and theres a plug that you can get at fordfuelinjection.com that will stop the idiot light. I think if you already havent visit JamesW's
website at http://www.midnightdsigns.com/james/its a wealth of info.
Old Aug 24, 2007 | 12:09 PM
Norm Peterson's Avatar
Norm Peterson
With a healthier cam than recent OE, you can get a little more natural EGR just because there's more overlap time (and on average a bit more lift on each valve during it). Adding a full OE dose on top of that might be too much anyway. IIRC, the LT4 'Vettes relied on natural EGR with cams of slightly different specs than the LT1's rather than use aseparate EGR circuit.
If you wanted to experiment a bit, adding a reduced amount of EGR is likely to actually increase your gas mileage slightly. Maybe something that you could manually switch on/off . . .
Norm
Old Aug 24, 2007 | 12:19 PM
takeoutexodus
you know speaking of mileage , I read an article that having a supercharged EFI 5.0 can sometimes even get you better mileage cruisin on the freeway[:-]
Old Aug 24, 2007 | 02:47 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Actually leaving the EGR on can increase fuel mileage, by 1-2 mpg. and it doesnt hurt ultimate performance as the computer shuts it out at WOT.
At the time I did mine it was just easier to get down to the simplest compoments, and cutting down the EGR spacer to 3/8in left just enough to mount the throttle linkage to, and made more room between the air intake horn & the shock tower.
Old Aug 24, 2007 | 04:39 PM
68EFIvert's Avatar
68EFIvert
I removed the EGR valve on my car by using a spacer that fordfuelinjection.com recommended (I have his harness and it is top notch. Removes all the unnecessary junk from the engine! ). The big benefit I saw for getting rid of my egr valve was the additional clearance with the shock tower. I was able to fit a C&L inlet tube in there for a few additional ponies.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
