cowl vent leaks
Old Aug 24, 2007 | 09:33 AM
Seabull's Avatar
Seabull
Default cowl vent leaks
Is it possible to stop the cowl vent leaks on my ' 64 1/2 ' without disassembling the dashboard and/or front fenders ? Thanx.
Old Aug 24, 2007 | 10:10 PM
Daze's Avatar
Daze
Default RE: cowl vent leaks
As a TEMPOTATY fix you can put on a cowl cover. NPD sells them; it is a Plexiglas piece that goes over the cowl vent. Having had one they work really well, but the real fix is to make the repair, buy drilling out all those spot welds and actually fixing it.
Old Aug 25, 2007 | 01:38 AM
blueovalfan's Avatar
blueovalfan
They also have under the dash kits that require dissassembly of the heating system. I installed this one in my car myself and was realatively easy. Most importanly you wont have the ugly plexiglas thingy visable from the outsound.
Old Aug 25, 2007 | 05:21 AM
andrewmp6's Avatar
andrewmp6
weld the cowl vent hole shut and get a vintage air unit.blueovalfan you mean something like this http://www.mustangdepot.com/OnLineCa...ent-repair.htm
Old Aug 25, 2007 | 12:23 PM
mikethebike's Avatar
mikethebike
The ONLY correct way to do it is to cut the cowl, do the repair and reinstall the cowl. Everything else is temporary.
Old Aug 25, 2007 | 12:34 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Yeah, the proper fix is a major undertaking, and a PITA, and leads to the "while I'm at it" syndrome. If you plan on keeping the car for a while and/or expect to sell it for big$$, its something that needs to be done right. wheather is repair or block off. Its sorta a Mustang owners right of passage.
The temproary fixes( hat or cover)are just that temporary, use'm just till you can get the proper repair done. And before you invest a lot of money into other restoration areas.
Or just do like I did for a number of years. It only leaks when it rains or wash water gets down it. Keep it outa the water, Hehheh, no leaks.
Old Aug 26, 2007 | 12:22 AM
blueovalfan
ORIGINAL: andrewmp6
Yep
Old Aug 26, 2007 | 12:30 AM
andrewmp6's Avatar
andrewmp6
the right way you pull out the windsheild and use a spot weld cutter and drill out the 100 some odd spot welds its real fun
mrtrodonet
Sep 19, 2020 03:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
