Outer wheel house removal
Old Aug 24, 2007 | 08:27 PM
green_blurr's Avatar
green_blurr
Default Outer wheel house removal
I have gotten this far with the removal of the wheel well with the help of my cutting wheel. How do i get in the back and get the spot welds drilled out?
[IMG]local://upfiles/43944/ADA4FC024E35434E949D7E414B9BBD82.jpg[/IMG]
[IMG]local://upfiles/43944/4B593AB91A1849A893CB630FBDDD0CA3.jpg[/IMG]
[IMG]local://upfiles/43944/3274F74DB0AA434C8B9CBE7282219C2D.jpg[/IMG]
Old Aug 24, 2007 | 10:04 PM
green_blurr
Default RE: Outer wheel house removal
Oh i thought this was a place where i could get advice may bad....
Old Aug 24, 2007 | 10:22 PM
JamesW's Avatar
JamesW
Come on..somebody's bound to have done this?!?
I'd think you'd go in from the inside to drill them out, but I've never done one.
Old Aug 24, 2007 | 10:48 PM
RGH69's Avatar
RGH69
Well, We did this on our 70 Fastback and the outer wheelwell was seam welded to the inner wheel well. We just used a grinder with a cutoff wheel to cut as close as possible to the seam. Then when we put the new one on and welded it to the existing seam.
After looking closer to your pics it appears that you are also removing the inner wheelhouse. You should be able to get all of the spot welds from the outside as well as the inside.
Old Aug 25, 2007 | 12:41 AM
Grimm's Avatar
Grimm
I have the body panel book at home. I'm on my Smartphone right now at my cousins house. If no one has anything to add when I get home I'll look it up.
Old Aug 25, 2007 | 12:47 AM
green_blurr
Thank you very much Grimm
Old Aug 25, 2007 | 03:25 AM
Grimm's Avatar
Grimm
ORIGINAL: green_blurr
I checked the book and there were no clear pages that showed the welds from the inner panel to the trunk.
For some reason I cannot upload the pictures of the pages I scanned. I will PM them to you. I hope they help out.
Tivo304
Aug 28, 2023 12:19 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
mungodrums
Oct 7, 2015 04:01 AM
