shift kit?
Old Aug 26, 2007 | 04:16 AM
dlynch's Avatar
dlynch
Default shift kit?
so me and some buddys got to bs'n about my coupe andI found a deal 500 bucks for a cleveland with a auto trans. they all say i need to keep it stick but i need more then a 3 speed. the engine needs a rebuild so would the tranny but i think its a hell of a deal. (being a student dont have much cash so ill settle for an auto) but if i was to get it i would put a shift kit in it. but i hear that the auto trans can not have over drive for it beable to have a shift kit. is that true? I plan on takin to car to college when graduate 1,500 miles from alaska to the lower 48 so I want to have over drive. so the question is can i have bolth overdrive and an shift kit?
Old Aug 26, 2007 | 04:33 AM
SS4LUNCH's Avatar
SS4LUNCH
Default RE: shift kit?
yes you can.
Old Aug 26, 2007 | 07:20 AM
andrewmp6's Avatar
andrewmp6
if you use a aod aode 4r70w im using a aod with a manual valve body i still gotta shift it but the overdrive is there its just another gear with a raito i froget for it to be a overdrive. if you want a cheap stick thats a overdrive look in to a t5
Old Aug 26, 2007 | 08:13 AM
Gary H's Avatar
Gary H
If it's a 351c, it wont have an overdrive trans. As far as I know anyway. And make sure it's a 351c and not a 351m. It would probably be cheaper to convert the 3spd to a 5spd then it would to find an AOD and rebuild it.. plus having to set up the TV cable to work with the carb. No clue what flexplate you'd need.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
