engine questions for cleveland 351
Old Aug 27, 2007 | 02:09 AM
71cleveland351's Avatar
71cleveland351
Default engine questions for cleveland 351
i just got a 1971 mustang (grande). The engine runs great but its old and i dont want to risk blowing gaskets and its never had much work done to it. All of the engine is pretty much original. Where should i start first in rebuilding it?
Old Aug 27, 2007 | 02:33 AM
andrewmp6's Avatar
andrewmp6
Default RE: engine questions for cleveland 351
strip it have it cleaned get the bore checked from there its up to you keep it stock or build it up.either way replace every gasket and seal and any bolt inside of it. if you reuse the cam make sure you dont have a lobe wore down.
Old Aug 27, 2007 | 11:30 AM
my77stang's Avatar
my77stang
^ there is nothing wrong with reuseing all the bolts for the motor - and you need to replace the cam and lifters if you are going to tear everything down.
to be perfectly honest with you, if the motor isnt leaking fluids now - leave the gaskets alone and just drive it. seriously - if its not broke, dont fix it.
Old Aug 27, 2007 | 12:36 PM
67mustang302's Avatar
67mustang302
Yeah, don't rebuild it unless something is wrong with it
Old Aug 28, 2007 | 07:59 AM
petec's Avatar
petec
Unless you are in the mood to spend money, just drive it.
If there is something wrong like a knock or water in the oil or some other reason to tear it down, like you want some performance parts thrown into it,then knock yourself out.
You can reuse the bolts, that engine was made years before the auto manufacturers went to torque to yeild bolts. Also, you can reuse the cam and lifters if they are in good shape unless you are going with a performance grind., but make sure you keep the lifters matched to their respective lobes.
If you are going to build the Cleveland you will find a quite potent engine when you are done. The key with it, as with any engine, is to know what it's strengths and weaknesses are as well as what you want from it and make the whole power packge from intake to rear gears match in reagrd to RPM range.
One other thing, is it a 351C 4V or 2V?
steelers743
Aug 31, 2015 07:16 AM
movielover40
Aug 27, 2015 10:13 PM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
HIS S-197
Aug 10, 2015 05:47 PM
89blueslug
Aug 10, 2015 07:20 AM
