grounds
Old Aug 27, 2007 | 11:52 AM
65stang142's Avatar
65stang142
Default grounds
on a 65 where are the headlights and parking lights suspose to be grounded to. I just replaced my turnsignal switch, rear taillight harness and head light switch and im still stuck with the same turn signal problems of when the lights are on left works fine right brightens up light goes on in dash but dosent blink. lights off the left are fine right side both rear tail lights blink please help
Old Aug 27, 2007 | 12:07 PM
JMD's Avatar
JMD
Default RE: grounds
The ground for the headlights and marker/turn signals for the front ground to the same spot near the headlight. Take off the headlight housing and you should be able to get to it.
The rears ground to the tail light mounting studs in the trunk.
Old Aug 27, 2007 | 02:52 PM
jlg2002's Avatar
jlg2002
Default RE: grounds
The directional lights/parking lights get a ground right at the parking light housing. Then, as JMD said, the head lights ground thu a wire directly on the headlight plug that attaches to the headlight buckets. Your problem seems to lie in the fact that one of the directional/parking light housings are not properly grounded to either the bulb holder or to the car chassis. This causes a circuit path for the parking lights to backfeed into the directionals (in the turn signal switch) causing the rears to come on. Grounding problems can be the most difficult to correct. Take the parking lamp housing off of the car and look for rust and corrosion, clean it up if found. Changethem if you want, NPD and others have good repops. You may need to ensure that the front valance is also properly grounded to the rest of the car. same for the headlightbucket grounding. same for the rear tailight grounds. And lastly, don't forget about that ground between the engine and the firewall. (although its probably ok clean it up anyways)
Old Aug 28, 2007 | 06:34 AM
65stang142's Avatar
65stang142
Default RE: grounds
I checked these but what other grounds are involved that could be an issue
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
Mr. D
Suspension
Sep 20, 2015 09:20 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
