Roush Small Block Crate Motor
Old Aug 28, 2007 | 03:23 PM
supraman408's Avatar
supraman408
Default Roush Small Block Crate Motor
i found a guy selling a roush small block crate motor for $2000. he said the engine is used but never been ran and the description he gave is:
“The heads are World Castings Roush 200's. The pistons are forged and the crank is most likely a 4340 forging as well with 28 oz./in. external balance. Static compression is 10.0:1 nominal. The cam is a hydraulic roller with approximately .550"/.570" lift and 225 to 235 degrees duration at .050". The rocker arms are full rollers as is the timing set.”
Fox Body Oil Pan
im planning on taking a trip to livermore Ca. to take a took at this 347 Roush motor up close and wanted to know what i should look for. what are some tale tale signs that this motor has been abused or if its even a roush motor at all. THANKS!
Old Aug 28, 2007 | 05:21 PM
JMD's Avatar
JMD
Default RE: Roush Small Block Crate Motor
ORIGINAL: supraman408
?? What ??
Yono tango
mtgldr
Feb 3, 2024 09:00 PM
Luke9222
Oct 22, 2015 11:55 PM
jaiidutch
Sep 14, 2015 10:29 AM
Sep 8, 2015 05:21 PM
