washing my engine
Old Aug 29, 2007 | 09:35 PM
xian67's Avatar
xian67
Default RE: washing my engine
idk my dad said "leave it up to me, i have this spray that works wonders"
Old Aug 29, 2007 | 10:27 PM
andrewmp6's Avatar
andrewmp6
sandwich bags over the dizzy and carb work great
Old Aug 30, 2007 | 11:58 AM
kalli's Avatar
kalli
in ireland you can't seem to buy motor cleaner/degreaser. So I went for a cleaner that is supposed to do the wheels (alloy wheel cleaner).
worked like a charm for me and is cheap bucks.
Old Aug 30, 2007 | 12:03 PM
boogerschnot's Avatar
boogerschnot
I picked up a bottle of Krud Cutter from target,, it smells just like simple green though,, and its been working wonders under my hood.. Being that I have been sitting on the A frame arm for the last couple of nights cleaning and prepping the entire bay for paint.. I also used some oven cleaner when i cleaned up my water pump,, that worked well but stank to high heavens..
Old Aug 30, 2007 | 12:31 PM
JMD's Avatar
JMD
Aircraft remover works well as a parts cleaner, but it takes the paint too.....
Old Aug 30, 2007 | 02:46 PM
jlg2002's Avatar
jlg2002
The way we used to clean cars in the shop was to put a rag in the carb throat and pull the dist cap off and put a rag in there (replace the cap) and then put a bag on the coil, the carb and the dist.. If you can get away with it, paint thinner makes a good degreaser. (dirt field)
Old Aug 30, 2007 | 02:52 PM
Sean W.'s Avatar
Sean W.
when i took my engine apart, i had a huge tub of diesel laying around so i soaked every part in that over night then the greese would just fall off...
Old Aug 30, 2007 | 02:58 PM
Starfury's Avatar
Starfury
Castrol SuperClean > all Diluted 3/1or 2/1 should bemore than enough for engine degreasing. Only catch is that you'll go into coughing fits if you breathe it. It's kinda toxic...lol.
Old Aug 30, 2007 | 03:00 PM
JMD's Avatar
JMD
ORIGINAL: Sean W.
Diesel in a tub = Parts Cleaner,,,,,, $3.00 a Gallon
Parts cleaner in a bottle = Diesel $3.00 a Quart
Old Aug 30, 2007 | 03:01 PM
Sean W.'s Avatar
Sean W.
satisfaction... pricless...
