electronic ignition?
Old Aug 29, 2007 | 09:41 PM
xian67's Avatar
xian67
Default electronic ignition?
so i was going to buy another mustang today. 66 couple. for 9K. it ran like **** thought and the paint was cheap. but he turned on the car without stepping on the gas. he told me he had an electric ignition or something like that. does MSD or any other company have any kits that come with everything i need to have an electirc ignition or w/e.
Old Aug 29, 2007 | 10:10 PM
JMD's Avatar
JMD
Default RE: electronic ignition?
Many will disagree with me, but I like the HEI setups, One wire hookup, built in coil, affordable (read cheap) and repair parts in stock at every parts store in America....
http://store.summitracing.com/partde...p;autoview=sku
<<Hey, there it is, to the left...<<
I bought one like this but for a 351,,
Old Aug 29, 2007 | 10:13 PM
xian67's Avatar
xian67
well is it good? do u turn ur car on with on stepping on the gas? and is it worth the money? seems kinda cheap to me
Old Aug 29, 2007 | 10:19 PM
JMD's Avatar
JMD
ORIGINAL: xian67
It is cheap, and yes the car starts without giving it any gas, and right now....
The components used in this distributor were used on all GM cars and trucks from 1974 through like about 1992... Very reliable, powerfull, and capable up to about 7.000 RPM.
Old Aug 29, 2007 | 10:31 PM
xian67's Avatar
xian67
so all i have to buy is this?
just that nothing else?
Old Aug 29, 2007 | 10:41 PM
JMD's Avatar
JMD
ORIGINAL: xian67
That is it, except that you will probably need new plug wires that will fit on the male terminals on the dist cap....
After thinking about this, I am not sure ifit will work with your stock Ford tachometer (if you have one).
The system is 100% self contained, coil is included.
You will however need to run a new ignition power wire because the stock wire is a "resistor wire" designed to reduce voltage to the stock coil. You will have to do this with any electronic system.
Old Aug 29, 2007 | 10:43 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
most carbed cars will start without stepping on the gas if its set up properly, it has nothing to do with the ignition
Old Aug 29, 2007 | 10:52 PM
xian67's Avatar
xian67
i have these spark plug wires.
i just get them 2 days ago.
Old Aug 30, 2007 | 02:39 AM
Starfury's Avatar
Starfury
ORIGINAL: rmodel65
+1
Although electronic ignition will help with reliable starts, and you can get a Pertronix unit for relatively cheap. No reason to replace your entire distributor.
Old Aug 30, 2007 | 06:35 AM
65StangFB's Avatar
65StangFB
Be careful with the HEIs because they will not work on all manifolds. I originally purchased one to run on a high rise but it was too large (Diameter). I ended up upgrading to an electronic ignition and a MSD box. Very happy
