Starting problems
Old Sep 4, 2007 | 02:04 PM
paddy187's Avatar
paddy187
Default Starting problems
OK ladies and gents, My stang will not start, ****, so I checked the battery and it was 13.5v but now I need to work out what has gone wrong so can anybody give me a check list so I can sort it out? There is no noise from the starter soI figure it could be the starter or the voltage regulator but need to test these. UnfortunatelyI can't get the starter testedat an auto-shop as they don't do that here any help would be much appreciated.
Paddy
Old Sep 4, 2007 | 02:08 PM
TexasAxMan's Avatar
TexasAxMan
Default RE: Starting problems
I bet it's the solenoid. Try replacing that first, it's a whole lot easier and cheaper too.
Old Sep 4, 2007 | 02:11 PM
paddy187's Avatar
paddy187
How can I test it? as it takes a while to get partshere innetherlands so I need to be sure cheers
Old Sep 4, 2007 | 02:15 PM
Starfury's Avatar
Starfury
Try TESTING it first. Throwing money at problems is never a great solution.
Take a screwdriver (with an insulated handle) and jump the big battery-side solenoid terminal to the nearest small terminaland see what happens. No click = bad solenoid. Click and start = power not getting from the ignition switch to the solenoid. Click and no starter noise = bad starter or wiring to starter.
Old Sep 4, 2007 | 02:31 PM
390bigblock's Avatar
390bigblock
id just buy a new starter silnoid and voltage regulator ther cost like 15 bucks each
paddy187's Avatar
paddy187
cheers will check at the weekend
Old Sep 4, 2007 | 02:35 PM
dnswwood's Avatar
dnswwood
Not so cheap where paddy lives ..in the Netherlands.
Yeah I'd bet on the selenoid being bad.Just jump it like mentioned above
Old Sep 4, 2007 | 02:38 PM
jlg2002's Avatar
jlg2002
Paddy187. On the attached schematic, using the words provided by Starfury, jumper #1 is how you check for a defective ignition input. Jumper # 2 checks for a bad solenoid. If niether cause the engine to crank, check for good grounds battery to engine block, engine block to frame, a loose connection, and/or12 volts at the starter end of the cable.
Old Sep 4, 2007 | 03:17 PM
paddy187's Avatar
paddy187
folks cheers for the advice we let you know when i get it sorted
Paddy
Old Sep 4, 2007 | 04:37 PM
Starfury's Avatar
Starfury
ORIGINAL: 390bigblock
A bad VR isn't going to keep the car from starting.
