1968 rear end
Old Sep 5, 2007 | 02:21 PM
knuckless's Avatar
knuckless
Default 1968 rear end
whats the difference between an 8 inch rear and a 8.8 inch rear? is there a difference or are they the same? i have a 68 with a 289 C4 and im trying to figure out what rear i have so i can either rebuild it or replace it for 347stroker
Old Sep 5, 2007 | 02:36 PM
superdavid's Avatar
superdavid
Default RE: 1968 rear end
The main gear on an 8.8 has .8" more metal for strength. If you're getting rid of your 8", I'd just go with a 9". A well built 347 will rape that 8...
Old Sep 5, 2007 | 02:38 PM
knuckless's Avatar
knuckless
so how do i find out if i have an 8 or a 8.8
Old Sep 5, 2007 | 04:12 PM
superdavid's Avatar
superdavid
I dunno about the 8.8 to 8. I know with a 9" its oval as opposed to the 8" being round...
Old Sep 5, 2007 | 04:18 PM
69 redruM's Avatar
69 redruM
8.8 has a diff cover on the back, 8" & 9" do not
8", 9" have drop out 3rd members, 8.8 dont
Old Sep 5, 2007 | 08:37 PM
Dancin52's Avatar
Dancin52
More than likely if you have a 289/302 you have a pumpkin 8. The only 8.8 I know of are on some newer fords, like the explorer. I had a friend put one in his 67 because he said it's stronger and already has the disc brake set up.
Old Sep 5, 2007 | 08:41 PM
Starfury's Avatar
Starfury
8.8's are a great upgrade for a smallblock. They're much lighter than 9" units, and much stronger than factory 2-pinion 8" units. They do require some fabrication (and often axle/brake swapping)before they will work in a classic, but it's not that big a deal. And on the upside, fox body (78-93) 8.8's are the perfect width for 67-68 Mustangs.
I've got an 8.8 housing sitting at a friend's waiting for me to build it. It'll easily hold against my 331.
Old Sep 5, 2007 | 09:10 PM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: knuckless
Ford didn't offer an 8.8" rear in '68 - only an 8" or a 9" in high HP/stick cars. Of course, an 8.8" could have been installed by a previous owner. As stated before, if there is a rear differential cover (you'd see bolt heads as viewed from behind), then it's an 8.8". No bolts heads = 8".
Old Sep 5, 2007 | 09:42 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
ORIGINAL: Starfury
+1 on what Starfury said.
An 8.8 is too wide for my 65, If I had a 67-68, I'd jump all over an 8.8. There are so many Exploders in wrecking yards with trac-loc 3.50-3.89-4.11 you can have a whole closet fulla ratios cheap. They are sturdy, even if ya break one your not out huge$$
Old Sep 6, 2007 | 01:07 AM
andrewmp6's Avatar
andrewmp6
its a 8 inch unless someone put a 8.8 in it .easy way to tell the rear of the axle is it welded on like a 9 inch nice and smooth the 8.8 has a bolt on cover like a gm or a dana axle.
