What Oil
Old Sep 5, 2007 | 03:24 PM
StangDB's Avatar
StangDB
Default What Oil
For a dry engine thats going together with all new parts(rings berings..) What oil would be best to use for break in? Would a fully synthetic like royal purple Work better? Or would it be best to go with regular 30 weight? or does it matter?
Old Sep 5, 2007 | 03:42 PM
JERM_1967stang's Avatar
JERM_1967stang
Default RE: What Oil
doesnt really matter i use castrol 10w40 and love it. i have a stock 289 with 59xxx original miles on it runs like new
Old Sep 5, 2007 | 04:17 PM
StangDB's Avatar
StangDB
Well, I see what your saying, but the first couple hundred miles is when the seals and rings nead the moast lube, i diddnt know if a full synthetic would be too slick.
Old Sep 5, 2007 | 05:43 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Don't use synthetics during the break in period...your engine actually needs less lubrication during this period so the mating surfaces have a chance so seat against each other.
Old Sep 5, 2007 | 06:04 PM
my77stang's Avatar
my77stang
from what i have been hearing lately, shell rotela (still has zinc in it) is the best oil to use while breaking in the motor
Old Sep 5, 2007 | 06:05 PM
cmc30250's Avatar
cmc30250
I just had a similar dilemma, rebuilt my inline 6 about 3 months ago. one of the guys who helped me who had rebuilt several older motors before said to go synthetic, and we used castrol gtx 10w30 and that worked just fine. It runs great now that its broken in, and it didnt take too long either. Ive heard that using synthetic on a new motor was bad for it too, but I dont know how true or false that is. Either way its just oil, as long as its in there doing what its supposed to do I think any decision you make will be alright. oh, but definitely do not go royal purple at first, its a really good motor oil but definitely not good for new engines, wait until about 2 or 3 oil changes before you use that. plus its expensive, and you should change the oil sooner than you would on an older engine with more miles, at least that is my understanding
Old Sep 5, 2007 | 06:32 PM
ThumperMX113's Avatar
ThumperMX113
Personally, I run 10w30. When breaking in my motors, I'll run the recommended oil, no synthetics, change after 50 miles. Fill it with some more conventional and change it with 500 miles on the odometer.
I like to run Royal Purple in my stuff after break in though, I'm sure you'll be more than happy.
Old Sep 5, 2007 | 06:34 PM
StangDB's Avatar
StangDB
Ok, thats what my machinist said too. its just that i have royal purple already cause of my truck, and i know its the shiz for that moter. But it has many miles on it too.
Any suggestions on headers?
Old Sep 5, 2007 | 06:39 PM
ThumperMX113
My oil routine is a little overkill but oil is cheap so I'd rather be safe than sorry. I've only helped build motors and thats what we normally do.
Now about the headers. What motor? What year?
Old Sep 5, 2007 | 06:53 PM
StangDB's Avatar
StangDB
302, its got 74 heads( so my engine builder says) its a 78' block though. I want to run a power rack and pinion stering.
So... ive got no clue what headers will work.
