What Oil
Old Sep 5, 2007 | 06:56 PM
ThumperMX113's Avatar
ThumperMX113
Default RE: What Oil
I'm not quite sure. Sorry.
Old Sep 5, 2007 | 07:11 PM
StangDB's Avatar
StangDB
no biggie
Old Sep 5, 2007 | 08:56 PM
Starfury's Avatar
Starfury
Oil is VERY important for break in. With a flat tappet cam, you need to be running something with high Zinc and Manganesecontent. Most street oils don't have this anymore due to EPA regulations. Use Shell Rotella T, Delo 400, Valvoline's 15W-40 fleet, or the equivalent, or you need to add some of Comp Cams' break in additive to the crankcase. The zinc bonds to the metal surfaces to create a protective boundary layerif there ever is metal to metal contact. This prevents cam lobes and lifters from being wiped out during breakin.
Do not use synthetics for the first 10k mi or so. It takes about this long for all of the parts in the engine to break in completely. Synthetics are so good at lubricating that they actually prevent proper breaking, especially where ring-seating is concerned. You need a little friction to properly seat the rings and wear the bearings into eachother. Once you hit 10k or so, go ahead and switch to synthetic if you want.
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
