Locker VS. Posi
Old Sep 7, 2007 | 12:21 AM
67mustang302's Avatar
67mustang302
Default RE: Locker VS. Posi
I have a Richmond Powertrax locker in mine, it works but can be finicky in tight radius turns. It also has some extra backlash in the driveline. I have no traction problems at all and it definately has no traction problems, but Imay end up going to a Detroit Tru-Trac. As far as something like a Tru-Trac with one wheel in the air, just ride the brake, or leave the parking brake partially engaged, that'll keep the axle loaded to provide the resistance the diff needs to operate properly
Old Sep 7, 2007 | 12:37 AM
Gun Jam's Avatar
Gun Jam
yeah the 4 x bias ratio is great unless you have 0 traction then 4x0 is still 0.
But if one wheel is in the air you clearly have bigger issues at hand than the bias ratio letting you down. True that you can use the park brake to get that resistance.
best of all there are no clutch packs to burn out !! Awesome!
Gun
Old Sep 7, 2007 | 12:39 AM
67mustang302
That's why I went with the Powertrax, I didn't wanna mess with clutch packs and friction additives. I just change the oil and drive it
p51pony
Dec 2, 2015 10:02 PM
JT76
Sep 20, 2015 11:32 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
whatsup62
Aug 29, 2015 01:25 PM
