throttle travel?
Old Sep 10, 2007 | 02:11 PM
Guitylerham's Avatar
Guitylerham
Default throttle travel?
Hey all,
I was wondering just how far the gas pedal should open up the carb throttle lever. The way it is set now, when I depress the pedal to the floor, the throttle lever on the carb only goes about half or less of it's total available travel. Wouldn't you want the pedal to completely open up the throttle on the carb (autolite 4100 1.08)?
Old Sep 10, 2007 | 02:38 PM
TexasAxMan's Avatar
TexasAxMan
Default RE: throttle travel?
You should be able to max out carb travel with the accelerator pedal. Sounds like yours needs adjusting.
Old Sep 10, 2007 | 02:43 PM
jlg2002's Avatar
jlg2002
You may want to look at your trans kickdown linkage for misadjustment while you're at it.
Old Sep 10, 2007 | 02:49 PM
Guitylerham
I'll take a look at the kickdown too. Currently my carb linkage rod is threaded in all the way so I will have to cut some more threads down the rod and cut off the end that sticks out too far. So when I do this, the pedal in will sit higher as well right since it will have more travel?
Old Sep 10, 2007 | 02:58 PM
jlg2002's Avatar
jlg2002
it will sit higher.
Old Sep 10, 2007 | 03:11 PM
Guitylerham
Thanks guys. I ended up just bending the rod a little to make it shorter and also made sure the kickdown was setup properly too.
chrisdbassplayer
Oct 13, 2015 06:53 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
JDWalton
Sep 24, 2015 08:47 PM
