69 specs
Old Sep 18, 2003 | 05:05 PM
Ton-E's Avatar
Ton-E
Default 69 specs
Does anyone know the specs on a 69 302 coupe(hp, tq, and weight). Its not a boss or a fastback. Or does anyone know a website where I can get this info from. Thanks for any help
Old Sep 22, 2003 | 12:53 PM
67aquafastback's Avatar
67aquafastback
Default 69 specs
Try doing a search on mustang facts you should be able to get the info that way.
Old Sep 29, 2003 | 07:24 PM
69freak's Avatar
69freak
Default 69 specs
I know a few details reguarding the 69 coupe. I would be glad to give you all the info including what all the codes mean in the door jam to axle ratios and where to find that information. I have a complete facts book on the 69. Engines, transmissions, interiors, exteriors colors and options.
Old Oct 1, 2003 | 04:19 AM
Ton-E's Avatar
Ton-E
Default 69 specs
Thanks man. Right now Im just wondering about the torque, hp and weight. In a couple of weeks am gonna be gettting into everything else alittle more. So if you dont mind I'll hit you up if I have any questions.
Old Oct 2, 2003 | 07:14 PM
69freak's Avatar
69freak
Default 69 specs
302 cid </P>
bore and stroke 4.00 x 3.00</P>
compression 9.5 to 1 </P>
brake hp 220 @ 4600rpm</P>
max torque300 @ 2600rpm</P>
the onlyweight spec I have is for the 200cid 3 speed manual which is 2890lbs</P>
I hope this helps</P>
Old Oct 3, 2003 | 05:45 AM
Ton-E's Avatar
Ton-E
Default 69 specs
Thanks alot this helps alot...
baddog671
Jul 26, 2016 01:20 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
Cavedawg
Sep 17, 2015 09:51 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
Webster454
Sep 7, 2015 04:59 AM
