car wont start
Old Sep 13, 2007 | 05:10 PM
slick66stang's Avatar
slick66stang
Default car wont start
the car wont start or even turn over. theres a new battery new starter fuses are good i can get jumped off but when i turn it off it just wont start up again. any ideas or suggestions
Old Sep 13, 2007 | 05:18 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Default RE: car wont start
Details needed.
Read this.
Troubleshooting starting systems
Old Sep 13, 2007 | 05:29 PM
slick66stang
thanks but that didnt help, i replaced the battery cause it was old and i needed a starter cause it was fried. today i went to put the key in and nothing happened. the lights dont even turn on. i have everything hooked up correctly and still nothing. im thinking its my alternator
Old Sep 13, 2007 | 05:37 PM
ky's Avatar
ky
America ftw
underdash wiring? maybe a wire got yanked accidently
Old Sep 13, 2007 | 05:47 PM
slick66stang
i dont think so it happened after i put the battery and starter on cause i started the car through the driver window
Old Sep 13, 2007 | 05:53 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: slick66stang
Why do you think it would be your alternator? If it started right up after you replaced the battery and starter and now the lights won't even turn on, you have a major battery drain somewhere. I would recharge the battery and see if it fires right up, then leave it disconnected overnight and see if it starts the next day when you reconnect it. If it does, then you need to start tracking your draining issues.
Old Sep 14, 2007 | 03:16 PM
jlg2002's Avatar
jlg2002
3 Questions:
1. is the new battery at 12V?
2.is the car in park or nuetral?
3. have you jumped around the solenoid to see if the the starter cranks.
PS: the alternator's job is to charge the battery (nothing else) and does not affect starting.
Old Sep 14, 2007 | 03:21 PM
TexasAxMan's Avatar
TexasAxMan
Follow jlg's advice, you should be on the road soon.
Old Sep 14, 2007 | 05:24 PM
LPlum's Avatar
LPlum
Well if you had started the car through the window, that tells me it's an automatic transmission.. They have a park/neutral safety switch. My switch went bad and the car would not start. Try moving the shifter handle, and or starting the car in neutral. This same switch needs to be adjusted properly. It is located on the left side of tranny and is slid over the shift shaft coming out of the tranny. This is a area that is prone to leak and then the switch gets contaminated in tranny fluid and fails. Good luck!
Lowell
djbigskrilla
Sep 20, 2022 01:04 AM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
89blueslug
Aug 10, 2015 07:20 AM
