Waterpump question
Old Sep 16, 2007 | 12:50 AM
kaiser18's Avatar
kaiser18
Default Waterpump question
I recently purchased a new water pump and was wondering if I need some type of gasket sealer when putting the new one on the block.
Also is it normal for water pumps to have two gaskets with a slim metal insert between the two?
Old Sep 16, 2007 | 01:37 AM
67mustang302's Avatar
67mustang302
Default RE: Waterpump question
I usually use a bit of sealer, a THIN coating, just to help it seal more easily. And yes, water pumps that have a metal backing plate(so it can better control flow) have a gasket between the plate and pump, and then a gasket between the plate and timing cover(if that's what you're talking about)
Old Sep 16, 2007 | 03:25 AM
boogerschnot's Avatar
boogerschnot
+1 I allways put a small bead of the red rtv stuff, let it set for about 5 minutes and then stick her together..
Old Sep 16, 2007 | 04:22 AM
kaiser18's Avatar
kaiser18
great, thanks for the replys guys
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
