Headlight Dimmer
Old Sep 16, 2007 | 11:16 PM
Loza_69Mach1's Avatar
Loza_69Mach1
Default Headlight Dimmer
hey you guys.... im having a problem with my lights inside my cluster.... I have a 1969 mach 1.. so i found out that the lights behind the cluster work and hardly go out... so someone told me it will be the dimmer switch... so is the dimmer switch is part of the headlight switch. so i took off the headlight switch...
Have you guys had this problem.... my headlights work and all other lights work but the cluster lights dont work....
whats the problem....
thanks
jr
Old Sep 16, 2007 | 11:30 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: Headlight Dimmer
I think you might be referring to the dash light dimmer which is built into the headlight switch (works by twisting the ****) instead of the headlight dimmer swich (which is a button on the floor board).
What exactly do you mean when you say "...the lights behind the cluster work and hardly go out..."?
Have you actually tried to adjust the brightness of the dash lights by twisting the headlight ****? How cool would it be if that solved your problem? If you have already tried that and it didn't help, I'm guessing the switch might be bad.
Good luck!
Old Sep 16, 2007 | 11:37 PM
Loza_69Mach1
sorry i met the lights behind the cluster DONT work... and ive tried to twisting the **** and nothing.... So what i did was took of the whole headlight switch off and im going to get a new one.. the head lights work and the fuse box looks good... so yeah
Old Sep 16, 2007 | 11:48 PM
NorCalTroy's Avatar
NorCalTroy
That makes more sense, hopefully a new switch will solve your problem. Post your results once you get the new one installed.
Good luck!
Old Sep 17, 2007 | 12:07 AM
Loza_69Mach1
thanks... ima get one tomorrow... thanks for your help... ill let you know what happens..
jr
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
