CRAZY VIBRATION!!!!!!!!
Old Sep 19, 2007 | 09:29 PM
gmata's Avatar
gmata
Default CRAZY VIBRATION!!!!!!!!
I've been having a vibration since i bought my car and i cannot figure out what's causing it.
It starts around 55-60 Mph and i think is comming from behind, i can feel it in my sit.
the vibration goes away when i take it out of gear, i've already installed a ne suspension Package from Laurel Mustang, its been Aligned, and i still feel the vibration. Any suggestions what is causing it?
Thanks
Old Sep 19, 2007 | 09:49 PM
stanging's Avatar
stanging
Default RE: CRAZY VIBRATION!!!!!!!!
Jack up your car and run it and see if it still vibrates, it could be the U-Joints, or the rear end , the tranny, or even tires out of balance.
Old Sep 19, 2007 | 11:31 PM
Gun Jam's Avatar
Gun Jam
Not sure what trans you have but c4 or whatever try it at the same speed but in a different gear. (if possible)
If you have a c4 for example lock it into second gear and accelerate to 55 or 60 and see if its any different.
Gun
Old Sep 20, 2007 | 01:54 AM
andrewmp6's Avatar
andrewmp6
sit in the back seat have someone drive it see if its worse in the back seat or not.
Old Sep 20, 2007 | 06:33 AM
Tomphot's Avatar
Tomphot
Make sure all of the lug nuts are properly attached as well.
Old Sep 20, 2007 | 09:41 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
what rear end?
1)check lugs
2)check u joints
3)this is the bad one, jack the *** end up and pull the diff cover and check your gears.
my bet is on #3
Old Sep 20, 2007 | 01:14 PM
PappaSmurf's Avatar
PappaSmurf
probably a stupid comment, but what about the balance of your rear wheels? if they arent balanced you get "speed wobble" at about 50-60mph. stupid suggestion, but its a cheap fix if it works.
Old Sep 20, 2007 | 03:56 PM
gmata's Avatar
gmata
Thanks for all the Ideas im going to try them and see what happens.
Old Sep 20, 2007 | 04:25 PM
my77stang's Avatar
my77stang
could also be bad axle bearings. mine are shot in the II and if i jack up the car i can actually move the wheel up and down a little bit
Old Sep 20, 2007 | 04:27 PM
Mustangdemon67's Avatar
Mustangdemon67
u joints or rear, i used to have the same problem
