CRAZY VIBRATION!!!!!!!!
Old Sep 24, 2007 | 10:04 PM
  #21
opie2@aol.com's Avatar
opie2@aol.com
Default RE: CRAZY VIBRATION!!!!!!!!
What has been done to the motor? Was the motor built without balancing the components? If your engine wasn't balanced, you could be in trouble trying to get rid of that vibration.
Old Sep 24, 2007 | 10:21 PM
  #22
gmata's Avatar
gmata
the engine was rebuild with out my supervision so i don't really know what to tell you :S...
Old Sep 24, 2007 | 11:48 PM
  #23
Aussie66Fastback's Avatar
Aussie66Fastback
have you made any other changes?
Windsors are "externally balanced" - one of the engine builders can give you better technical terms than i can. In essence the harmonic balancer and flywheel should be balanced together. If you have changed one and not the other, this could be part of the problem (very rough description which i am sure one of the builders can correct).
the harmonic balancer is held together with some sort ofbonded rubber...if the outer part starts to break away and turns relative to the inner, it will cause a balance issue. Can either replace or better to pull it off and get it checked.
torque converter needs gearbox out to get at it and then take it to a good trans shop.
Sorry my technical descriptions are terrible!
Old Sep 25, 2007 | 10:53 AM
  #24
gmata's Avatar
gmata
I'll just buy a new engine and a new transmission.LOL
i wish haha
mtgldr
Feb 3, 2024 09:00 PM
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
