Leakdown Test How To?
Old Sep 20, 2007 | 08:36 PM
palerider's Avatar
palerider
Default Leakdown Test How To?
I've got a 70 Mach 1 blow some smoke on start up and when I rev - hoping it's just valve stem seals - sat for a long time. In any case plan on doing a compression test this weekend and then a leakdown if warranted.
Found a lot ofgood information on compression tests but not much on leakdowns. Can anybody point me to Leadkdown test for Dummies post or site? thanks
Old Sep 20, 2007 | 09:15 PM
fast66's Avatar
fast66
Default RE: Leakdown Test How To?
I've always just done the regular compression test first, then I squirt a small abount of thin oil (like sewing machine oil) into the cylinder throught the spark plug hole, and redo the compression test. Comparing the two results for each cylinder will tell you if its your rings or valve seats. Ie if the wet test is higher, you have ring problems. if it mains the same, you have valve seat problems.
This does not directly tell you anything about you valve seals. It tells you the condition of your compression rings, and this is indicative of the condition of the oil scraping rings. If the rings look as though they are ok form doing this test, and you are blowing smoke, this then indicates that you may have valve seal issues.
BTW smoke on startup is usually indicitive of valve seal wear, rather that rings anyway.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
