1968 Mustang Help
Old Sep 21, 2007 | 09:06 AM
david7677's Avatar
david7677
Default 1968 Mustang Help
Im having a problem finding a name for a part that screws into the top of
the Thermostat Housing Unit it has a hose that connect just below the carb I was fiinally able to find the Thermostat housing unit at a local auto supply does anyone know the part Im talking about ? Also the Mustang is a 1968 V6 on the air filter cap it says 200 but the auto store are saying its a 303 any help on this issue ? Thanks for any info on my problems.........
Old Sep 21, 2007 | 10:06 AM
TexasAxMan's Avatar
TexasAxMan
Default RE: 1968 Mustang Help
It's nota V6, unless it has been replaced. It is probably a 200 I6. Find a new auto store if they said a 303, if it's a V8 it might be a 302 but not a 303.
Since you're in Texas, no emission equipment is required on a 68, so you can just replace the thermo housing with on that does not have the provision for the vacuum switch (I believe that is what you are talking about). Of course, if you are restoring, you should put it back stock.
Old Sep 21, 2007 | 10:17 AM
Jaded's Avatar
Jaded
OK, it should be a 200 Inline 6, not a V-6.
The line on top of the housing should be normal plumbing and if I remember right it's part of the choke mechanism. A look online found part number K116A and I found this by searching for Ford Falcon instead of Mustang.
Old Sep 21, 2007 | 10:22 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
It's an 200ci I6
Old Sep 21, 2007 | 04:41 PM
Cogtx's Avatar
Cogtx
I have an I6 200ci without the hose/line from thermostat to carb. Here is a pic. You might be able to get a plug for that at the parts store or checkMustang parts online.
[IMG]local://upfiles/19071/8C69A6A1098A4747921DA9A294D4BCDF.jpg[/IMG]
Old Sep 21, 2007 | 04:54 PM
david7677's Avatar
david7677
Okay this is more information than I have recevied any where else thank for the help I just wasnt sure about pluging it the Housing unit i found came with a plug but I didnt know what would happen or if the part was nessary.
Old Sep 21, 2007 | 05:07 PM
Cogtx's Avatar
Cogtx
I was looking at my 67 shop manual for the I6. It shows some were equiped with a coolant heated spacer located between the carb and the manifold. Does yours have a spacer between the carb and manifold? or better yet do you have a picture of your carb setup? If you check out ebay, you might get a good deal on a shop manual which is invaluable for working on these classic cars...keep us posted on your repairs...
Old Sep 22, 2007 | 08:13 AM
david7677's Avatar
david7677
I will check on that spacer and get back to you
Old Sep 22, 2007 | 08:25 AM
david7677's Avatar
david7677
Here are some pic of the car I got alot of work ahead of me but it fun to do.
[IMG]local://upfiles/80256/E621330F5F55416BB33D6DF95ED58DEC.jpg[/IMG]
[IMG]local://upfiles/80256/04C58A86F4E242FAAD050B690036C4E4.jpg[/IMG]
[IMG]local://upfiles/80256/2FF6BADF882D476DBABEEE53695942A9.jpg[/IMG]
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Philhampton1
Aug 21, 2015 12:04 PM
daytooday
Aug 11, 2015 09:22 AM
Super_Chief
Aug 11, 2015 03:54 AM
